QOS prioritize EIGRP traffic.
zarjer
Hi we are having issue in configuring QOS markings and prioritization on our 4500-x Core switches. Please see below configurations:
access-list 100 permit eigrp any any
class-map match-any EIGRP_TRAFFIC
 match access-group 100
policy-map EIGRP_POLICY
 class EIGRP_TRAFFIC
  set dscp af31
  bandwidth percent 30
int po6
 vlan-range 800
  service-policy output EIGRP_POLICY
When I apply service-policy on L2 port-channel using vlan-range command I am getting this error
Failed to attach policy-map EIGRP_POLICY to interface Port-channel6 vlan 800
But when I apply service-policy on L2 Port-channel only no in vlan-range command
command is accepted but it is not showing in the show run. please see image attached.
Also when I apply it on SVI interface vlan 800, still command is accepted  but it is not showing in the show run.
Giuseppe Larosa
Hello @zarjer ,
post
show module
show version
Effective QoS capabilities depend on the type of supervisor you have and IOS XE image version.
To be noted your service policy should be accepted only when applied outbound as the policy-map is a scheduler CBWFQ.
Besides this, EIGRP packets should be marked with CS6 by default and 30% of bandwidth may be too much if the target is to protect EIGRP traffic.
Hope to help
Giuseppe
Hi @Giuseppe Larosa,
Please see show module and show version:
MTP_4500X#show module
Switch Number: 1 Role: Virtual Switch Active
Chassis Type : WS-C4500X-32
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 32 4500X-32 10GE (SFP+) WS-C4500X-32 JAE205000NE
2 8 10GE SFP+ C4KX-NM-8 JAE210101UT
M MAC addresses Hw Fw Sw Status
1 2cd0.2d62.cbc0 to 2cd0.2d62.cbdf 2.0 15.0(1r)SG12 03.08.01.E Ok
2 881d.fc5e.fa20 to 881d.fc5e.fa27 1.0 Ok
Mod Redundancy role Operating mode Redundancy status
1 Active Supervisor SSO Active
Switch Number: 2 Role: Virtual Switch Standby
1 32 4500X-32 10GE (SFP+) WS-C4500X-32 JAE204905M1
2 8 10GE SFP+ C4KX-NM-8 JAE210101Q9
1 2cd0.2d62.a2c0 to 2cd0.2d62.a2df 2.0 15.0(1r)SG12 03.08.01.E Ok
2 a0ec.f9e5.4e48 to a0ec.f9e5.4e4f 1.0 Ok
1 Standby Supervisor SSO Standby hot
MTP_4500X#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.08.01.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 28-Jan-16 22:17 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG12
MTP_4500X uptime is 3 years, 14 weeks, 1 day, 12 hours, 20 minutes
Uptime for this control processor is 3 years, 14 weeks, 1 day, 12 hours, 22 minutes
System restarted at 06:57:11 ph Sun Feb 19 2017
System image file is "flash1:unknown"
Jawa Revision 3, Winter Revision 0x0.0x41
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-C4500X-32'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4500X-32 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE205000NE
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
22 Virtual Ethernet interfaces
80 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101 (will be 0x2301 at next reload)
Hello @zarjer ,
first of all, the configuration register value is  not the standard one at next reboot:
I recommend to change it back to 0x2101 and save the configuration.
please refer to the following document about QoS configuration on 4500 with IOS XE 3.8
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-8-0E/15-24E/configuration/guide/xe-380-configuration/qos_mrg.html
In the section Queueing and Scheduling it explains that each port supports 8 output queues
The Catalyst 4500 series switch supports 8 transmit queues per port. Once the decision has been made to forward a packet out a port, the output QoS classification determines the transmit queue into which the packet must be enqueued.
Queues are assigned when an output policy attached to a port with one or more queuing related actions for one or more classes of traffic. Because there are only eight queues per port, there are at most eight traffic classes (including class-default, the reserved class) with queuing action(s). Classes of traffic that do not have any queuing action are referred to as non-queuing classes. Non-queuing class traffic use the queue corresponding to class-default.
Active Queue Management
Active queue management (AQM) is the pro-active approach of informing you about congestion before a buffer overflow occurs. AQM is done using Dynamic buffer limiting (DBL). DBL tracks the queue length for each traffic flow in the switch. When the queue length of a flow exceeds its limit, DBL drop packets.
There is also a section about per port per Vlan QoS that can be useful for you, as it is what you tried to configure.
However, you will note that this per port per Vlan QoS uses only policers
Hope to help
Giuseppe
Joseph W. Doherty
BTW, as an aside, dynamic routing protocols generally use CS6.
