WAN to LAN
amh4y0001
Level 3
Level 3
Is it possible to combine tWAN ports on Cisco ISR to work as LAN?
Hello @amh4y0001 ,
your understanding is correct on branch small routers these WAN ports are dedicated for routing with the internet or whatever you want to connect to.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello @amh4y0001 ,
WAN ports are routed ports and they can be used as internet uplinks.
IF you need additional LAN ports the best choice is to add an 8 ports LAN switch to be connected downstream one LAN port of the router.
Hope to help
Giuseppe
Hi and thanks for reply. So if I understand correctly, WAN ports can't be used as LAN?
My bad, I didn't quite get "8 ports LAN switch to be connected downstream one LAN port of the router".
Hello @amh4y0001 ,
Hope to help
Giuseppe
Thanks for confirmation.
Joseph W. Doherty
Depends on what you're trying to accomplish. (I also assume the "WAN" port is copper/fiber Ethernet.)
Many small router WAN Ethernet ports cannot do "switch" L2 (doesn't always mean you cannot connect them on a LAN) and/or offer "special" features more useful to WAN than LAN, such as enhanced QoS and/or additional buffer resources (again, doesn't always mean cannot be used with a Ethernet LAN). (BTW, this is somewhat like asking how a switch with "uplink" ports can be used.)
You also mention "combine" ports. Much depends on how you wish to combine and what you're going to connect to.
