QOS Trust
Desmond Smith
I have a Cisco 4507 switch plugged into a Websense device.
Analysis of VoIP traffic has shown that QoS DSCP values are preserved across switchports until reaching the Websense appliance, attached to the switch, at which point they are discarded. Proper handling of VoIP traffic requires preserving QoS DSCP values end-to-end across the LAN and WAN for good call quality.
How do I configure the port that is connected to the websense device?
Is it the mls qos trust extend cos 5 command?
Any help is appreciated.
Desmond
Desmond,
The command "mls qos trust extend cos 5" is used
for interfaces that connect to cisco ip phones. This command
tells the phone to set the COS to 5 for all packets/frames from
the PC port on the phone. This is in the direction towards the 4500 interface.
To mark all traffic as as COS 5 out of the interface you
would need to use a policy map along the lines below:-
class-map match-any WEBSENSE
match any
policy-map WEBSENSE
class WEBSENSE
set cos 5
interface fas 5/5
desc WEBSENSE
service-policy out WEBSENSE
Hope this helps
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
7 Replies 7
Hello
If the switch has mls Qos enabled then by default Qos is set to override dscp to zero (sh mls Qos)
So yes if qos is enabled then you will need to trust the dscp values on either the trunk interface coming into the switch or in the switchport
Res
Paul
Kind Regards
Paul
Desmond,
match any
policy-map WEBSENSE
class WEBSENSE
set cos 5
interface fas 5/5
desc WEBSENSE
Hope this helps
Alex.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
So you're saying the Websense proxy is dropping the markings?  If so, the ideal solution would be for the Websense proxy to stop doing that.
Otherwise, assuming there are multiple markings you need to preserve, you need a policy, on some downstream (from the Websense) transit device, to analyze and remark traffic with their appropriate QoS markings.  Depending on the complexity of the analysis, the ingress port, from the Websense attached to your 4507, would be the most logical place for such a policy.
Do know, that Catalyst switches, by default, when QoS is enabled, will erase QoS markings.  I assume this isn't the issue on the 4507.  If it is, just trust (or trust and verify) traffic entering the 4507.
Also know, QoS changes much on the latest 4500 sups, i.e. sup7 QoS is different from sup V QoS.
Desmond Smith
So basically the statement I was suggesting can only be used for Cisco Ip phones that are connected. I am not sure if I can get them to change the Websense settings but if I can't then the easiest way would be to set up a class map and policy map and mark the packets with cos 5 as they leave the switchport interface that is connected to the Websense device?
Thanks all for your help and suggestions!
Desmond
Hi Desmond,
You need to configure the parameters on the cat 4500 switch.
Inayath
Yes on the interface connected to the Websense device.
Desmond
Yes Perfect.
Inayath
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
