Question about 3750G Stack
hxmengmetro
Level 7
Level 7
Hi All,
If the master switch in one 3750G stack failed, which slave will take control? Does the slave inherit all the settings from master?
Thanks a lot.
Lou
Nagaraja Thanthry
When the current master goes down, the slave switch will takeover the master
role and inherit all the settings from the master. Here is a document that
explains the master election. If all other parameters remain same, the
switch with lowest MAC ID will be selected as master.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuratio
n_example09186a00807811ad.shtml#election
Hope this helps.
NT
Nagaraja Thanthry
Hope this helps.
NT
Thanks a lot! It's helpful.
