Question about EIGRP summary-address advertisements
rkartch
I have a router running EIGRP, with a summary address configured on one interface, using the "ip summary-address eigrp" command. This creates a route to null0 in the local routing table, for that summary address, like this:
D 10.10.0.0/16 is a summary, 3d21h, Null0
The summary works the way I want it to, and all's good so far, but...
I'll be adding a new EIGRP neighbor for this router to peer with. My requirement is that the new neighbor receive the advertisements from this router for the *specific* routes in that summary network, but *cannot* receive the summary advertisement itself. The new neighbor will not be hanging off the interface with the summary address configured; it will be on a different interface.
My questions are these:
1) In a default configuration (with no special filtering set up), would the new neighbor receive an EIGRP advertisement for the summary route? I would guess that it would, since it appears in the table of the existing router as an EIGRP route.
2) If the answer to the first question is yes, how can I filter the summary route from the outbound advertisements, while still allowing all the smaller routes from that network through? A prefix-list would be ideal for this (and is how I handle the issue when redistributing between protocols)--but as far as I can tell, I can't apply a prefix-list to simple advertisements between routers speaking the same protocol. If I use a distribute-list with a regular ACL, I'm not sure how I can prevent the summary route, say 10.10.0.0/16, but still allow, for instance, the smaller network 10.10.0.0/24 to be advertised.
Any thoughts?
5 Replies 5
rkartch
Well, I may have just answered my own question... When I first asked the question, I was foolishly reading the documentation on options for filtering outbound advertisements, and the doc (configuration guide for 12.4T) only showed the option of using an ACL with the distribute-list. However, I just went into my router and did a "distribute-list ?" under EIGRP configuration just to see whether any additional options showed up, and it looks like I can use a prefix-list after all:
Router(config-router)#distribute-list ?
<1-199> IP access list number
<1300-2699> IP expanded access list number
WORD Access-list name
gateway Filtering incoming updates based on gateway
prefix Filter prefixes in routing updates
route-map Filter prefixes based on the route-map
So... never mind. Guess I'll stop reading the documentation from now on!
(I'm still curious about whether the router will try to advertise the summary to the new neighbor, but I guess as long as I can block it with a prefix-list it doesn't really matter.)
Hello Rachel,
and so the new EIGRP will not see the summary route that is only sent out the interface where it is configured
per interface control of summarization means so.
Hope to help
Giuseppe
Hi:
The summary address will only be advertised to the router that receives it directly from the interface.
See below.
Switch 1 has eigrp neighbors to switch2 and a router. Switch 2 gets summary route. Router does not.
VICTOR
Switch_2#sh ip ro
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 2 subnets
R 1.1.1.1 [120/1] via 22.22.22.1, 00:00:14, FastEthernet0/20
C 1.1.1.2 is directly connected, Loopback0
50.0.0.0/30 is subnetted, 1 subnets
D 50.50.50.0 [90/30720] via 22.22.22.1, 00:00:06, FastEthernet0/20
5.0.0.0/32 is subnetted, 1 subnets
R 5.5.5.5 [120/10] via 22.22.22.1, 00:00:14, FastEthernet0/20
6.0.0.0/32 is subnetted, 1 subnets
R 6.6.6.6 [120/10] via 22.22.22.1, 00:00:14, FastEthernet0/20
22.0.0.0/30 is subnetted, 1 subnets
C 22.22.22.0 is directly connected, FastEthernet0/20
7.0.0.0/32 is subnetted, 1 subnets
R 7.7.7.7 [120/10] via 22.22.22.1, 00:00:15, FastEthernet0/20
8.0.0.0/32 is subnetted, 1 subnets
R 8.8.8.8 [120/10] via 22.22.22.1, 00:00:15, FastEthernet0/20
10.0.0.0/22 is subnetted, 1 subnets
D 10.80.0.0 [90/156160] via 22.22.22.1, 00:00:07, FastEthernet0/20
Switch_2#
Switch_2#
Switch_2#
Switch_2#sh ip ro 10.80.2.0
Routing entry for 10.80.0.0/22
Known via "eigrp 10", distance 90, metric 156160, type internal
Redistributing via eigrp 10
Last update from 22.22.22.1 on FastEthernet0/20, 00:00:19 ago
Routing Descriptor Blocks:
* 22.22.22.1, from 22.22.22.1, 00:00:19 ago, via FastEthernet0/20
Route metric is 156160, traffic share count is 1
Total delay is 5100 microseconds, minimum bandwidth is 100000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
SWITCH#1
interface Loopback10
ip address 10.80.1.1 255.255.255.0
interface Loopback11
ip address 10.80.2.1 255.255.255.0
interface Loopback12
ip address 10.80.3.1 255.255.255.0
Switch_1#sh run | be router eigr
router eigrp 10
network 10.80.1.1 0.0.0.0
network 10.80.2.1 0.0.0.0
network 10.80.3.1 0.0.0.0
network 22.22.22.1 0.0.0.0
network 50.50.50.1 0.0.0.0
no auto-summary
interface FastEthernet0/20 <-------------------FACES SWITCH#2. SENDING SUMMARY ROUTE TO SWITCH #2.
no switchport
ip address 22.22.22.1 255.255.255.252
ip summary-address eigrp 10 10.80.0.0 255.255.252.0 5
end
This is a first...ran out of characters.
See routers routing table.
Router#sh ip ro
O E1 1.1.1.1 [110/21] via 50.50.50.1, 00:20:44, FastEthernet0/0
O E1 1.1.1.2 [110/21] via 50.50.50.1, 00:03:03, FastEthernet0/0
C 50.50.50.0 is directly connected, FastEthernet0/0
C 5.5.5.5 is directly connected, Loopback1
C 6.6.6.6 is directly connected, Loopback2
D 22.22.22.0 [90/30720] via 50.50.50.1, 00:03:32, FastEthernet0/0
C 7.7.7.7 is directly connected, Loopback3
C 8.8.8.8 is directly connected, Loopback4
10.0.0.0/24 is subnetted, 3 subnets
D 10.80.2.0 [90/156160] via 50.50.50.1, 00:07:11, FastEthernet0/0
D 10.80.3.0 [90/156160] via 50.50.50.1, 00:07:11, FastEthernet0/0
D 10.80.1.0 [90/156160] via 50.50.50.1, 00:07:11, FastEthernet0/0
Router#
Router#
How come the router does not learn these summary addresses ?, it it because it is directly connected to the same switch but with no summary set on the interface ?
