Question about HSRP
Andy3055
Hi everyone
Greetings!
I've already finished config on routers.
And how should I configure the multilayer switch in the diagram below if I want to create HSRP with router 0 and router 1?
Should IP addresses on G0/1 and G0/2 on multilayer switch be in a same network?
Andy
2 Accepted Solutions
balaji.bandi
On the switch make sure Gi 0/1 and 0/2 in same VLAN to HSRP to work. (if you have done the config on router)
On the Router the IP should be same as other ( it can not be 10.0.1.1 - it should be 10.0.0.3)
best suggestion is
router 1 should have 10.0.0.2
router 2 should have 10.0.0.3
Virtual IP 10.0.0.1
show standby brief show you one as master other one slave
still issue post the config to look and suggest
BB
On the switch you do not give any IP address on the interface, they should just Layer 2
config t
Vlan 10
interface range gi 0/1-2
switchport mode access
switchport access vlan 10
interface fas0/1
ands configure your PC with IP address 10.0.0.4 gateway 10.0.0.1 should work as expected
BB
8 Replies 8
balaji.bandi
best suggestion is
Virtual IP 10.0.0.1
BB
Hello everyone
I have a question about HSRP.
I've configured related ports on router1, router2 and multilayer switch. But there's some issues.
Can you help me to solve it,please?
Here's my config text and results below:
!router1-active
en
conf t
int g0/0
ip add 10.0.0.2 255.255.255.240
standby 1 priority 150
standby 1 ip 10.0.0.1
standby 1 preempt
no shut
!router2-standby
en
conf t
int g0/1
ip add 10.0.0.3 255.255.255.240
standby 1 priority 90
standby 1 preempt
no shut
!multilayer switch
en
conf t
int g0/1
ip add 10.0.0.4 255.255.255.240
no shut
int g0/2
ip add 10.0.0.5 255.255.255.240
no shut
Why not follow below thread which you have already - i have answered there :
https://community.cisco.com/t5/switching/question-about-hsrp/m-p/4512086#M514658
BB
Jon Marshall
They need to be in the same vlan and IP subnet.
Jon
Andy3055
Thanks for your help. I've updated the diagram and typed config into devices. But still have some issues.
!router1-active
en
conf t
int g0/0
standby 1 preempt
no shut
!router2-standby
en
conf t
int g0/1
standby 1 preempt
no shut
!multilayer switch
en
conf t
int g0/1
no shut
int g0/2
no shut
Here's the new diagram
config t
Vlan 10
interface fas0/1
BB
Thank you. This is helpful.
