question about ospf default information originate metric !!
Dr.X
Level 2
Level 2
i have  topology worjing with ospf routing protocol
R1(Asbr)-----SWITCH --------R2
R1 configs:
router ospf 1
router-id 1.1.1.1
default-information originate metric-type 1
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 176.66.66.1
control-plane
R1 is reditributing into ospf ,
now on R5 , why the metric is 3 ,  why it is not 2 ????????
R5#sh ip route
O*E1 0.0.0.0/0 [110/3] via 192.168.40.1, 00:40:23, FastEthernet0/0
R5#SH IP OSpf Database External
            OSPF Router with ID (5.5.5.5) (Process ID 1)
                Type-5 AS External Link States
  Routing Bit Set on this LSA
  LS age: 580
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 0.0.0.0 (External Network Number )
  Advertising Router: 1.1.1.1
  LS Seq Number: 80000002
  Checksum: 0xDE4
  Length: 36
  Network Mask: /0
        Metric Type: 1 (Comparable directly to link state metric)
        TOS: 0
        Metric: 1
        Forward Address: 176.58.79.2
        External Route Tag: 1
R5#SH IP OSpf Database ASbr-summary
                Summary ASB Link States (Area 4)
  LS age: 1018
  Options: (No TOS-capability, DC, Upward)
  LS Type: Summary Links(AS Boundary Router)
  Link State ID: 1.1.1.1 (AS Boundary Router address)
  Advertising Router: 5.5.5.5
  Checksum: 0xBE63
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 1
R5#sh ip ospf interface f
R5#sh ip ospf interface fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
  Internet Address 192.168.40.5/24, Area 0
  Process ID 1, Router ID 5.5.5.5, Network Type BROADCAST, Cost: 1
  Transmit Delay is 1 sec, State DROTHER, Priority 1
  Designated Router (ID) 3.3.3.3, Interface address 192.168.40.3
  Backup Designated router (ID) 4.4.4.4, Interface address 192.168.40.4
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:09
as u see the cost of R5 interface is 1 ,
AS you see above , the cost to asbr is 1 , and the metric source of type 5 is 1 ,
so why R5 put the cost 3 in the routing table ?????
regards
Hello Ahmed,
my guess is confirmed
Routing entry for 176.58.79.0/30
  Known via "ospf 1", distance 110, metric >>> 2<<<<<<, type inter area
The forwarding address has to be known via an internal route to have the external route installed and the metric to the FA is 2 so total metric to 0.0.0.0/0 becomes 3.
see the following document about OSPF FA effects
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080124c7d.shtml
Hope to help
Giuseppe
6 Replies 6
Reza Sharifi
Where is r5 located?  Can you post a diagram of the network with all the devices?
Giuseppe Larosa
Hello Ahmed,
the LSA type 5 for 0.0.0.0/0 originated by R1 has the forwarding address set:
May you post on R5 show ip route 176.58.79.2 ?
My guess is that the different metric is because of the forwarding address that is seen as a sort of next-hop to the external route.
If forwarding address was 0.0.0.0 = ASBR self then the total metric would be 2 as you expect.
In this case with the forwarding address set the metric may be the result of seed metric + metric to the forwarding address
Hope to help
Giuseppe
hi ,
Giuseppe,
u may be right ,
here is my topology which im working in
http://www2.0zz0.com/2012/09/22/18/471819576.png
plz give me more detail about my issue
regards
R5#sh ip route 176.58.79.2
  Known via "ospf 1", distance 110, metric 2, type inter area
  Last update from 192.168.40.1 on FastEthernet0/0, 00:52:51 ago
  Routing Descriptor Blocks:
  * 192.168.40.1, from 1.1.1.1, 00:52:51 ago, via FastEthernet0/0
      Route metric is 2, traffic share count is 1
R5#
Hello Ahmed,
Hope to help
Giuseppe
appreciate ur help ,
i modifies the default route with  null 0 destination instaed of next hop ip ,
and the metric wascorrected to 2 ,
thanks for notifiying about notifying about this trick
regards
