QOS ACL for snmp and icmp to/from monitoring server.
rawatsandeep
Friends,
Problem : When there is a high congestion on the Remote site router wan link, our monitoring server reports it as down, and the reason being not getting reply to icmp packets or high responce time to get a reply back. I do not want this to happen during congestion period.
Please note that Inbound making is done on L3 switch and Outbound service policy is applied to Remote site router WAN interface.
- So when the Remote router replies to ICMP packts sent by monitoring servers , echo reply packets will be matched by default class, and due to congestions at  some point of time will be randomly droped. I belive router self generated packets like ssh, icmp, will be given default treatment.
Monitoring server -------- Head end Router (ASR1000) QOS applied here too ------- (Outbound policy applied on WAN interface)Remote site Router (2951) -------- L3 Swith (3750) (Inboud marking done here).
One way I think to address this is to create new class maps and policy-map on remote site router to mark the packets sent destination (Monitoring server ip ) marked with higher DSCP value or bandwith percentage. but would need to be done head end router too.
Example:
access-list 101 permit icmp host x.x.x.x host 10.x.x.x echo
access-list 101 permit icmp host x.x.x.x host 10.x.x.x echo-reply
access-list 101 permit udp host x.x.x.x host 10.x.x.x eq snmp
class-map match-all QPM_ICMP-Traffic
description Outbound ICMP traffic queue
match access-group 101
policy-map QPM_Lab-Policy-Group
class QPM_ICMP-Traffic
bandwidth percent <X>
interface Se0/0
ip address 192.168.251.6 255.255.255.224
service-policy output QPM_Lab-Policy-Group
Note we have below configs on L3 switch:
From L3 Switch at remote sites : (ACL is same at Head end)
class MARK-OPS-ADMIN-MGMT
set dscp af31
ip access-list extended OPS-ADMIN-MGMT-ACL
permit tcp any any eq tacacs
permit tcp any eq tacacs any
permit tcp any any eq 161
permit tcp any eq 161 any
permit udp any any eq snmp
permit udp any eq snmp any
permit udp any any eq snmptrap
permit udp any eq snmptrap any
permit udp any any eq syslog
permit tcp any any eq telnet
permit tcp any eq telnet any
permit tcp any any eq 22
permit tcp any eq 22 any
What do you suggest the best way to modify QOS ? and resolve the issue.?
Sandep Rawat
0 Replies 0
