ā01-07-2013 01:47 AM - edited ā03-07-2019 10:56 AM
HI , i have the topology below :
as we see all the L2 links are trunk ,
ive created vlan 10 with svi as in figure
note that on R1 i have ip 192.168.1.4/24 as siv interface
uptill now i didnt configure L3 interfaces . i mean i just configured the green circuile in the figure
but i have problem
why when i try to ping 192.168.1.3 from from R1 it fail ????
but if i put ip on svi on vlan 1
every thing is okay !!!
my question is another point .
if i changed vlan 10 to vlan 1 with the same ips , every thing is ok
whats wrong with me ??
ā01-07-2013 01:57 AM
Simplifying your topology for better understanding,
(vlan10)R2(E0/3)-----L2--------(E0/3)R1(Vlan10)
You have 192.168.1.3/24 on R1 vlan 10 and 192.168.1.3/24 on R2 vlan 10. When you ping from R1, it fails. Is my assumption right on above simplified topology?.
Am I assuming right that you have E0/3 on both R1 and R2 as trunk interface?. if so, what is the native vlan you have enabled on R1 and R2?.
Do you mena, when you move the IP address on both R1 and R2 to vlan1, it works?.
-Nagendra
ā01-07-2013 02:11 AM
hi
-Nagendra ,
its as u said . but samll correct
You have 192.168.1.4/24 on R1 vlan 10 and 192.168.1.3/24 on R2 vlan 10.
native vlan is vlan 1
when changing the the vlan 10 to vlan 1 , its okay !!
but why the ping & arp request go through native vlan ??
regards
ā01-07-2013 02:15 AM
Can you share the configuration from R1 and R2?. I hope you have vlan 10 created on both R1 and R2.
-Nagendra
ā01-07-2013 02:31 AM
SW1#sh run
Building configuration...
Current configuration : 1212 bytes
! Last configuration change at 11:33:40 EST Mon Jan 7 2013
version 12.2
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5
ip cef
no ipv6 traffic interface-statistics
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Ethernet0/0
switchport
switchport trunk encapsulation isl
switchport mode trunk
duplex auto
interface Ethernet0/1
switchport
duplex auto
interface Ethernet0/2
switchport
switchport access vlan 10
switchport mode access
shutdown
duplex auto
spanning-tree portfast edge
interface Ethernet0/3
switchport
duplex auto
interface Vlan1
ip address 1.1.1.5 255.255.255.0
interface Vlan10
ip address 192.168.1.4 255.255.255.0
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
exception data-corruption buffer truncate
end
SW2#sh run
Current configuration : 1055 bytes
! Last configuration change at 11:33:05 EST Mon Jan 7 2013
version 12.2
hostname SW2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
no ip address
shutdown
duplex auto
ip address 10.20.30.2 255.255.255.0
duplex auto
no ip address
shutdown
duplex auto
switchport
duplex auto
interface Vlan1
ip address 1.1.1.6 255.255.255.0
interface Vlan10
ip address 192.168.1.3 255.255.255.0
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
ā01-07-2013 03:20 AM
You dont seems to have the vlan created. Can you try the below,
config t
vlan 10
exit
-Nagendra
ā01-07-2013 04:50 AM
hi ,
its created because it was transferred by vtp ,
anyway i did as u suggested but the same issue !!!
no ping
ā01-07-2013 04:53 AM
hi , im wondering about an issue.
i think when i ping from MLS , the traffic is originated from switch and seems to be untagged and will go to vlan 1 ,
so i cant ping other switches in vlans not from vlan 1 >
is my pointview may be correct ?
regards
