question about #show ip arp in cisco 2960g switch !
Dr.X
Level 2
Level 2
hi ,  i would like to ask about  sh ip arp in cisco switch ,
if i type show ip arp in cisco switch , it only display the arp in vlan 1 , although i have alot of vlans conected to pcs and servers , but only it dispaly the arp of vlan 1 ,
on my switch  i have  an ip under interface vlan 1
how to display the app of all vlans ??
regards
cadet alain
arp  request is sent on directly connected neighbours in the same vlan, for other vlan hosts you'll have  only arp entry for default-gateway.
Regards.
Alain
cadet alain
Regards.
Alain
do u think putting an ip address on sw from each vlan will solve the issue ??
in that case then if the devices are directly connected and on corresponding vlan then yes you'll see output in the arp cache after communicationg with them.
Regards.
Alain
