question about start ipv6 in L2TP tunnel between LAC & LNS router
Dr.X
Level 2
Level 2
hi ,
my system topology is an ADSL technoglogy topology
here is my  topology :
http://www.rracuares.com/wp-content/uploads/2010/07/PPPoE-over-L2TP.png
im just want to ask , wt config i need to modify LAC router and LNS router so as the end users get an ipv6 ips .
plz  pay attention only on LAC & LNS Routers
now ,
both of them are using ipv4 support and the infrastructure is ipv4. and the end user get only ipv4 ips .
my question is , wt config we need to modify so as the L2TP tunnel become ipv6 and the end users get ipv6 ips on thier adsl router ??
here is the config below :
LNS CONFIG:
LNS#sh running-config
Building configuration...
Current configuration : 1318 bytes
version 12.4
hostname LNS
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn-group 1
accept-dialin
  protocol l2tp
  virtual-template 1
terminate-from hostname LAC
source-ip 1.1.1.8
l2tp tunnel password 0 rracuares
username rejohn@cuares.com privilege 0 password 0 rejohn
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
ip address 1.1.1.8 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet1/0
ip mtu 1492
peer default ip address pool PPPoE-POOL
ppp authentication pap
ip local pool PPPoE-POOL 20.20.20.2 20.20.20.254
no ip http server
no ip http secure-server
ip classless
control-plane
line con 0
exec-timeout 0 0
password 123
logging synchronous
line aux 0
line vty 0 4
end
LAC :config
LAC#sh running-config
Current configuration : 1230 bytes
version 12.4
hostname LAC
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn search-order domain
vpdn-group 1
request-dialin
  protocol l2tp
  domain rracuares.com
initiate-to ip 1.1.1.8 priority 1
local name LAC
bba-group pppoe global
virtual-template 1
ip address 1.1.1.6 255.255.255.0
duplex auto
speed auto
ip address 10.252.102.49 255.255.255.240
duplex auto
speed auto
pppoe enable group global
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3/0
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip classless
control-plane
line con 0
exec-timeout 0 0
password 123
logging synchronous
login
line aux 0
line vty 0 4
login
end
reagrds
Ahmad
Hello Ahmad,
You are welcome
did u mean that the PSTN side dont need any modifications so as to support ipv6 to customers adsl router ??
Quite correct - the PSTN side does not need any modifications. Assuming that the client uses PPPoE, his IP traffic is encapsulated as follows:
Ethernet|PPPoE|PPP|IPv4/6
The transmission chain in DSL service just takes the entire Ethernet frame with whatever contents it may have and carries it over the provider's network to the ISP aggregation router. The IPv4/IPv6 packets will first emerge and get processed on the LNS. No other device will see or process them sooner.
Best regards,
Peter
16 Replies 16
Peter Paluch
Hello Ahmed,
The only necessary change should be to enable IPv6 on the Virtual-Template 1 on the LNS. The L2TP protocol tunnels entire PPP frames received from the PPPoE client. Whether the PPP frames carry IPv4 or IPv6 packets is irrelevant to the L2TP operation. No configuration change on the LAC is necessary.
So the modifications on the LNS are these (the commands shown here should be added to your existing configuration):
ipv6 unicast-routing
ipv6 local pool IPv6POOL 2001:DB8:FFFF::/48 64
interface Loopback1
ipv6 address 2001:DB8::1/128
ipv6 unnumbered Loopback1
ipv6 mtu 1492
no ipv6 nd ra suppress
peer default ipv6 pool IPv6POOL
The pool IPv6POOL allocates a /64 subnet to each connected client from the 2001:db8:ffff::/48 range (IPv6 pools are prefix-based, not address-based). The no ipv6 nd ra suppress command is necessary to allow sending Router Advertisements through each PPP session to allow the client to use stateless autoconfiguration.
Suggestions to your existing configuration:
  • On the LAC, the IP address on the Fa1/0 interface is not necessary for client PPPoE connectivity. If you are performing other IP communication through the interface then you may leave it there, but otherwise, this IP address is not required for clients and their PPPoE sessions.
  • On the LAC, the ip unnumbered command on the Virtual-Template1 interface is useless and shall be removed.
Best regards,
Peter
hi  peter ,
Thank u very much for ur reply , u really suprprised  me , i thought there will be alot of modifications in the LNS & LAC so that we config  support ipv6 to clients.
any way ,
i would like to mention that the above tpology is just  a simulation on GNS3 , but actually i work in an isp and on my LNS server there are similar configs ,
i have only an access to LNS not on LAC.
but again ,
im really appreaciting ur help cause u gave me a breif info about my modifications configs .
regards
Ahmad
Hello Ahmad,
You are welcome
Best regards,
Peter
hi peter ,
thanks very much
soon i will try it , and give u a reply
regards
Ahmad
hi peter , i would like to ask about another behaviuor
wt will haped if i configured on the virtual template both ipv4 and ipv6 ips and pools .
the customer will get v4 or v6 ???
assume the config below is configured:
loopback1 is ipv4
loopback 2 is ipv6
ip unnumbered Loopback1
ip tcp adjust-mss 1412
no logging event link-status
ipv6 unnumbered Loopback2
peer default ip address pool a1 a2
peer default ipv6 pool z1
ppp mtu adaptive
ppp authentication pap vpdn
ppp authorization vpdn
ppp accounting vpdn
will the customer get ipv4 or ipv6 ??
regards
Hello Ahmad,
PPP is an awesome protocol in the regard that it provides an ability for both parties to individually negotiate each higher-level protocol that should be carried over the PPP session. Both endpoints have to agree on the particular higher-level protocol, otherwise this protocol will not be carried over the PPP link. Now, your configuration prepares the LNS for both IPv4 and IPv6. Now it is up to each client what protocols it wants to carry over the PPP session. If a client comes and is willing to negotiate both IPv4 and IPv6, it will get both IPv4 and IPv6 address and connectivity. If a client comes and negotiates only a selected protocol, either IPv4 or IPv6, this negotiated protocol will be the only one that is carried over the link, and the other protocol will be suppressed.
So in the end, it depends on the client and its configuration what IP protocol will be enabled on this PPP connection. The client will get IPv4, IPv6 or both depending on its own configuration. Your LNS is currently prepared to provide both.
Best regards,
Peter
hi peter ,
thanks thanks thanks
regards
Ahmad
hi peter ,
i woild like to ask another question in the same subject , which is about vpdn .
if i  type
#debug vpdn error
on the LNS router ,
i have the following console message on my LNS router ,
L2X_ADJ: Vi563:midchain adj repopulate, nothing to do
L2X_ADJ: Vi957:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1133:midchain adj repopulate, nothing to do
L2X_ADJ: Vi737:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1159:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1127:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1164:midchain adj repopulate, nothing to do
L2X_ADJ: Vi931:adj notify change failed, no session
L2X_ADJ: Vi12:midchain adj repopulate, nothing to do
L2X_ADJ: Vi793:midchain adj repopulate, nothing to do
L2X_ADJ: Vi496:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1063:midchain adj repopulate, nothing to do
L2X_ADJ: Vi994:midchain adj repopulate, nothing to do
L2X_ADJ: Vi98:midchain adj repopulate, nothing to do
L2X_ADJ: Vi357:midchain adj repopulate, nothing to do
L2X_ADJ: Vi874:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1160:adj notify change failed, no session
L2X_ADJ: Vi1019:adj notify change failed, no session
L2X_ADJ: Vi1159:adj notify change failed, no session
L2X_ADJ: Vi1122:adj notify change failed, no session
L2X_ADJ: Vi1117:adj notify change failed, no session
L2X_ADJ: Vi927:adj notify change failed, no session
L2X_ADJ: Vi346:adj notify change failed, no session
L2X_ADJ: Vi147:adj notify change failed, no session
L2X_ADJ: Vi1015:adj notify change failed, no session
L2X_ADJ: Vi1147:midchain adj repopulate, nothing to do
L2X_ADJ: Vi355:midchain adj repopulate, nothing to do
L2X_ADJ: Vi1097:midchain adj repopulate, nothing to do
as u see , there are two types of output :
one about no seesion and the 2nd one  about no thing to do ,
note that this command was typed on a production network similar to the topology above in the post .
my question is , is there an error from PSTN side ??? or it just a natural event ???
regards
Hello Ahmed,
To be honest, I do not precisely understand what these messages mean. However, the "adj" in their name suggests that they refer to building the adjacency database (a component of the Cisco Express Forwarding architecture, or CEF) - the frame rewrite information used to encapsulate packets routed to or via adjacent nodes. I would personally say that the messages saying "failed" refer to sessions that have been recently terminated. If there are no connectivity issues reported by clients I see no reason to get worried. There are processes running in IOS that may report a "failure" but that does not necessarily mean that something is wrong.
Best regards,
Peter
thanks peter
hi peter ,
recently i recived ipv6 prefix from ripe and want to assing ipv6 address to user from virtual template pool
actaully i have a problem when using ipv6 local pool ,
the prefix is
2aaa:aaaa::/64
i  want the ipv6 on the virtual tepmlate to be ==> 2aaa:aaaa::1/64      and want the pool to assign ipv6 addresses to  hosts , i want to give  the hosts an ips from  2aaa:aaaa::2=========>2aaa:aaaa:ffff:fffff:ffff:ffff:fffff:ffff
if  we  type # ipv6 local pool 2aaa:aaaa::2/64 64             ===========> i get an error that the ip address in the virtual  template is  from the ipv6 poool !!!!!!!!!!!!!
wt should i do ???
regards
Hi Ahmed,
I will look into the issue once again in the morning. Don't worry, I haven't forgotten you.
Best regards,
Peter
ok peter , im waiting u
