Question for OSPF NSSA
tinhnho123
Level 2
Level 2
Hi Guys,
I currently have a setup:  Internet-- Router--Firewall #1--Firewall #2 --- Layer 3 Core (please see attachment). Below are configuration of the 'Router'.
Router:
interface GigabitEthernet0/0
 description to ISP
 ip address 192.168.1.2 255.255.255.0
 ip nat outside
 load-interval 30
 negotiation auto
end
interface GigabitEthernet0/1
 description to Firewall #1
 ip address 172.20.1.1 255.255.255.0
 negotiation auto
end
router ospf 1
 area 25 nssa default-information-originate metric-type 1
 redistribute static metric-type 1 subnets
 network 172.20.1.0 0.0.0.255 area 25
  distribute-list 50 in
ip nat inside source list 40 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 40 permit 172.22.10.0 0.0.0.255
access-list 50 deny   any
I have few questions for these commands :
What exactly are they doing in this configuration above? and why do I need them?
Thanks.
m.kafka
Level 4
Level 4
I am missing a statement "ip nat inside" on one of the interfaces (possibly on Gi0/1)
About your questions:
I can assume from the configuration that the firewall is ABR and the only purpose of the router is to inject a default route into OSPF. For this purpose the area 25 nssa default-information-originate will generate an external type 1 lsa for 0.0.0.0/0 if the router has an active default route in the routing table. (The redistribute static shouldn't be necessary).
If there was an ip nat inside command somewhere this command will Port-Address-Translate all communication from the internal network 172.22.10.0/24 to the address of the Gi0/0 interface. I can only assume, that this network is reachable through the firewall but there is a static route missing for this network. Even if this network was announced via ospf the distribute-list 50 in statement would prevent this network from entering the routing table.
I believe this configuration needs a thorough check and maybe one repair or another...
Best regards, MiKa
Hello
Maybe previously this router only required a default route to gain access to the all routes within the ospf domain its atached to, And as such It didnt need a large routing table to query to gain outside access - Then a opsf stub area would be a good choice to use.
Now lets say due to necessity this router is now attaching to an external network it needs to advertise this external network back into the ospf domain,  but the stub area its in will not allow this to happen
However - to keep the same characteristic of a stub area but to be able to advertise external networks, the router has become a NSSA  (not so stubby area) and a opsf ASBR (Autonomous system boundary router) - a router that links an ospf network to an external network other than ospf)
So as you can see its in nssa 25 and it redistributing its static routes to the exteranl network into ospf and performing Network address translation .
res
Paul
Kind Regards
Paul
