Question on 65k QOS configuration
naveenb
Currently our company has 65k switch where qos is enabled. it has the following configurations for video traffic and network protocols traffic with the following threshold values
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 2 3
wrr-queue cos-map 3 3 6 7
wrr-queue queue-limit 40 30 15
wrr-queue random-detect min-threshold 1 40 60 80 80 80 80 80 80
wrr-queue random-detect max-threshold 1 70 80 100 100 100 100 100 100
no wrr-queue random-detect 2
no wrr-queue random-detect 3
wrr-queue threshold 2 60 80 100 100 100 100 100 100
wrr-queue threshold 3 60 80 100 100 100 100 100 100
what is the advantage of changin that to different queue/threshold
wrr-queue cos-map 3 5 4
wrr-queue cos-map 3 4 7
wrr-queue random-detect min-threshold 2 80 80 100 100 100 100 100 100
wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 3 80 70 80 90 100 100 100 100
wrr-queue random-detect max-threshold 3 100 80 90 100 100 100 100 100
prakadeesh
naveen a 6500 can have qos based on the module. so modules have priority q + normal transmit.
some have only normal queues without any priority.
I can see that the cos map being changed from using queue2 and 3 to just queue 3. so any  frames with cos 3 4 6 7 will be serviced in queue 3 with various thresholds. threshold indicated in random detect have two values
minimum threshold define at what % of the queue limit should wred kick in to start weighted random discarding packets beyond this % threshold limit
max is the maximum threshold in % of queue capacity that will start the all packet discard beyond this point scenario.
