Question on configuring VRRP tracking !!!!!
Hi All,
I am trying to configure vrrp tracking on cisco 6509 running 12.2(18) version.but i am getting error as:
VRRP: Tracking not supported on IP Address owner...
Please see the config below:-
Switch6509(config-subif)#vrrp 2 ip 10.26.15.40
Switch6509(config-subif)# vrrp 2 description Shariff
Switch6509(config-subif)# vrrp 2 ip 10.26.15.40
Switch6509(config-subif)# vrrp 2 timers learn
Switch6509(config-subif)# vrrp 2 authentication text cisco
Switch6509(config-subif)# vrrp 2 track 1 decrement 30
Thanks in advance.
Shariff
"If a VRRP group is the IP address owner, its priority is fixed at 255 and can not be reduced through object tracking."
Reference: http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtvrrptk.html#wp1043317
I hope this helps.
Best regards.
Massimiliano.
I hope this helps.
Best regards.
Massimiliano.
Thanks for the update. I have another issue, We can't see the mac-address on the PFC but we see it on the DFC.
Kindly let me know if i am missing anything here?
Thanks in advance.
Shariff
The mac-address table is only on DFC (distributed) without affecting the PFC.
I hope this helps.
Best regards.
Massimiliano.
Hello Massimilliano,
Can you tell me what am i doing wrong here:-
track 1 ip route 0.0.0.0 0.0.0.0 reachability
(config)#interface GigabitEthernet2/0/0.202
(config-subif)# vrrp 1 ip 10.10.10.2 usman
(config-subif)# vrrp 1 timers learn usman
(config-subif)# vrrp 1 authentication text passvrrp usman
(config-subif)# vrrp 1 track 1 decrement 30
This is the same way i am configuring mentioned in the cisco link but still getting the error.
Usman
