question on EEM applet
cashqoo
hi guys,
is it possible for eem applet to track if a specific ip route exist in the routing table?
if yes, is any configuration example i can refer to?
thanks
Marwan ALshawi
You can use ip sla tracking to look into a certain route
And configure this track ti be watched in the eem and you can fo an action based on the track state
track 100 ip route 10.0.0.0 255.0.0.0 reachability
event manager applet route_unreachable
event track 100 state down
action 1.0 syslog msg " the route to network x is become unreachable!"
Hope this help
If helpful rate
Marwan ALshawi
Hope this help
If helpful rate
