Question on IP Routing, little confused on routing.
CKluck001
So question, trouble with some routing issues.
I am trying to a static route a device in my VLAN 12, however it is not working like what I planned.
I know this works 0.0.0.0 0.0.0.0 64.65.66.68 this will route everything out.
But I am trying the following 35.34.33.32(Host) 255.255.255.255 64.65.66.68, not getting anywhere.
On the Palo device I have this setup -
35.34.33.0/24 (1/3) 64.65.66.67
So can I route a host within a vlan or do I have todo something like policy based?
16 Replies 16
ahmedshoaib
Level 4
Level 4
Hi;
I have following queries to identify the issue you are facing:
1. Will Vlan 12 (35.34.33.0/24) subnet gateway is configured on Router?
2. Will the PC on vlan 12 can ping Router?
If both answer is yes then I think it's not issue with reference to routing may be your PaloAlto firewall is blocking the traffic coming from Vlan 12 subnet.
Thanks & Best regards;
1) Yes that is vlan 12
Vlan IP address - 35.34.33.1
Vlan Host IP - 35.34.33.32
2) Yes it should because its the machine will on the same vlan 12 subnet
Currently I can't even ping my gateway from the host, using this static route
I am not clear where you are applying this route. And perhaps confused about what you are trying to accomplish with this route. Can you clarify this?
Rick
Rick
Richard I clicked the correct answer button wrong.
I am applying this route to router, I want to route just one machine through the device for testing purpose.
Thanks for the clarification. The route that you are applying will not do what you want it to do. What that route will do is to say that to reach host 35.34.33.32 forward the packet to 64.65.66.68 which is the opposite direction from where the packet should go.
I am not entirely clear on what you are trying to accomplish in this testing. If I interpret the diagram correctly the router has only two interfaces, the interface where the host is connected and an interface leading to the Palo device.  If you want to test whether traffic from this host will be forwarded correctly the default route that you mention should be sufficient. All you need to do is to be sure that the host default gateway does point to this router and then generate some traffic.
If the intent of your test is to prevent traffic from any other host from being routed then you probably need an inbound access list which permits only the host you are testing with.
Rick
Rick
So..
My route actually should be 64.65.66.68 255.255.255.255 35.34.33.32 or what would that be?
Hi;
If you can't ping even gateway as you mentioned then it might be PC in not on Vlan12 or Switch to Router  Vlan 12 is not allowed?
Can you share you Router & Switch Configuration?
Actually not being able to ping the host is easily explained when the route 35.34.33.32(Host) 255.255.255.255 64.65.66.68 is used. This route tells the router that to reach 35.34.33.32 it should forward traffic toward Palo which is the wrong direction.
Rick
Rick
Hi Richard;
As we go to initial case noted where @CKluck001 already mentioned that he configured a default router toward paloalto on Router:
& on PaloAlto have the route of vlan12 (35.34.33.0/24) via 64.65.66.67.
Which seems to be not a routing issue. In 2nd post also @CKlick001 mentioned:
"Currently I can't even ping my gateway from the host".
Which seems to be either host, switch port (is not configured on vlan 12) or port b/w Switch & Router vlan 12 is not allowed.
You are certainly entitled to your own opinion about what is the nature of the problem. But in the original post in addition to the two routes that you mention the original poster also says this "I am trying the following 35.34.33.32(Host) 255.255.255.255 64.65.66.68 "
If vlan 12 is on interface FA0/0 and PaloAlto is on interface FA0/1 and if there is a static route for host 35.34.33.32 which says to get to that host use FA0/1 then in my experience this does create a routing problem. And the result of that routing problem is that attempts to ping 35.34.33.32 will fail because the ping packets are being forwarded out FA0/1.
Rick
Rick
I think I am now getting  what I am doing wrong.
On The router I should have something along this line.
99.99.99.0 255.255.255.0 64.65.66.68
Actually for what you have in the picture you do not need that static route for 99.99.99.0. As long as you have the default route 0.0.0.0 0.0.0.0 64.65.66.68 your router will forward its outbound traffic to PaloAlto and your router does not need to know that PaloAlto will use 99.99.99.0 to get to the Internet.
This discussion has been through so many posts and suggestions that I would like to take a step back and ask for a fresh statement of what is the current problem. What is not working the way that you want it to work?
Rick
Rick
I would like route just machine, I would like just learn how to route one machine vs the whole entire subnet.
Hi;
Can you confirm that following items:
1. Can PC on Vlan12 (35.34.33.12) can ping Router (35.34.33.1)? As you mentioned in old post that it's not working.
2. If PC ping the gateway then can you verify the PaloAlto firewall policy, whether it's allow or deny?
3. If PC can't ping the gateway then the issue either with PC or switch port (is not configured on vlan 12) or port b/w Switch & Router vlan 12 is not allowed.
