Question on show ip interface brief
wfqk
Level 5
Level 5
Hi I used command show ip interface brief. and I got the following output. My question is why Port G1/20 has TFTP, while other ports have unset ?
Thank you
SW-(config)#do show ip interface brief
GigabitEthernet1/18    unassigned      YES unset  down                  down
GigabitEthernet1/19    unassigned      YES unset  down                  down
GigabitEthernet1/20    unassigned      YES TFTP   down                  down
GigabitEthernet1/21    unassigned      YES unset  down                  down
5 Replies 5
Reza Sharifi
Can you post the output of "sh run int g1/20"
Hi Thanks for your reply
SW-05#sh ip int bri | b 1/18
SW-05#sh run | b 1/18
interface GigabitEthernet1/18
 no ip address
interface GigabitEthernet1/19
 no ip address
interface GigabitEthernet1/20
 no ip address
Hope this helps
Method
The method field has the following possible values:
RARP or SLARP—Reverse Address Resolution Protocol (RARP) or Serial Line Address Resolution Protocol (SLARP) request
BOOTP—Bootstrap protocol
TFTP—Configuration file obtained from TFTP server
manual—Manually changed by CLI command
NVRAM—Configuration file in NVRAM
IPCP—ip address negotiated command
DHCP—ip address dhcp command
unassigned—No IP address
unset—Unset
other—Unknown
Mike
Have a look at table-1 in this link.
It does not appear to be the case right now, but the configuration method for interface g1/20 was obtain by tftp server at one time.
If you reboot the router (warning downtime) that will probably change.
https://www.cisco.com/c/en/us/td/docs/optical/cpt/r9_5/command/reference/cpt95_cr/cpt95_cr_chapter_010001.pdf
gothlzcisco
If you had this interface configured at some point recently and then reset the configuration, you might see TFTP there.
If you put an IP address on that interface and reboot, you'll see it go to manual the next time you reboot.
