Question on untagged vlans and PVIDs
We recently implemented some SG300s in our environment and with that introduced vlans to to segregate our voice and data traffic.
vlan 169 for data. vlan 179 for voice
The technician changed the default vlan from 1 to 1000 and made the pvid on all ports 169. That alone confused me and didnt make much sense. But what really confuses me is he put all of the ports in general mode, added 169 untagged, and made the pvid 169.
My questions:
If he was going to make the pvid 169 on all ports why did he code 1000 as the default vlan?
Why explicitly add 169 untagged to the port? If 169 is the default vlan on that port will frames not be placed in 169 untagged as it is?
switchport mode general
switchport general allowed vlan add 169 untagged
switchport general pvid 169
voice vlan enable
Everything works so it's fine and I understand there's more than one way to skin a cat. I'm just curious. We ended up adding a few switches after the project was over and I placed my ports in trunk mode with native vlan as 169 and they work just the same. 2 commands vs 4.
switchport trunk native vlan 169
voice vlan enable
Hilda Arteaga
Hope you're doing well
This topic is related to the available Virtual Local Area Network (VLAN) features and configuration options specific to this platform (Cisco Small Business 300 Series Managed Switches)
Basically, you can configure a port as an access port, as a trunk port,as a general port or as a customer port.
General ports can receive tagged or untagged packets. Use the switchport general allowed vlan Interface Configuration mode command to add/remove
VLANs to/from a general port and configure whether packets on the egress are tagged or untagged.
By default the port is not member in any VLAN and packets are transmitted untagged.
!The following command configures the VLAN membership mode (access, trunk, general or customer) of a port. Default is trunk mode which specifies a trunking layer 2 VLAN port. General mode specifies a full 802.1Q supported VLAN port
!Adds VLAN id (PVID) 169 to the port and specifies that the port transmits untagged packets for this VLAN
!The PVID is the VLAN to which incoming untagged and priority-tagged frames are classified on a general port
!The following command enables OUI Voice VLAN on an interface
voice vlan enable
!A L2 trunk interface allows all VLANs by default, and the native VLAN is the only VLAN which is not tagged in a trunk.
voice vlan enable
So, basically the previous are two different approaches to achieve the same goal in a different way for each option. The difference is that with the 'switchport mode general' option, the port is not member in any VLAN (restrictive approach) and that you've to explicitly specify if the VLANs added to the port will be tagged in egress, while 'switchport mode trunk' is a more permissive approach requiring additional configuration commands to set restrictions if required.
For additional details, please consult the command reference guides in the link below.
Reference link:
http://www.cisco.com/c/en/us/support/switches/small-business-300-series-managed-switches/products-command-reference-list.html
