Cisco show interfaces 'multicast' output
tedauction
Hello, can someone please explain the difference between IP multicast and 'multicast' counters in the output of the 'show interface' command below ?
30 second output rate 990000 bits/sec, 354 packets/sec
1304746780 packets input, 493036831857 bytes, 0 no buffer
Received 170140 broadcasts (0 IP multicasts)
0 watchdog, 165658 multicast, 0 pause input
1350689708 packets output, 649080670343 bytes, 0 underruns
400493493 output errors, 0 collisions, 0 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Thank you.
tedauction
Hello, perhaps the field 'IP multicasts' refers to PIM traffic from other  routers ?
