10-01-2013 09:27 AM - edited 03-07-2019 03:46 PM
Does anyone know if one can mix-n-match a WS-X6748-GE-TX/ CFC with a
WS-X6748-GE-TX/ DFC4 in a 6509-E chassis running a SUP 2-T?
I know the WS-X6748-GE-TX/ CFC will work by itself and the
WS-X6748-GE-TX/ DFC4 will work by itself, but will they work together in the same chassis?
Thanks for your time.
Bryant C Mothershed
10-01-2013 04:23 PM
Yes you can use both. The traffic from the CFC will get sent to the supervisor for switching versus being switched on the card itself with the dfc card.
10-01-2013 07:42 PM
Hello
I agree with Glen.
WS-X6748-GE-TX is compatible with SUP2T either with CFC or DFC 4X daughter card. With that said any existing WS-X67xx Line cards can be upgraded by removing their existing CFC or DFC3x and replacing it with a new DFC4 or
DFC4XL. They will then be operationally equivalent to the WS-X68xx linecards.
Note: With DFC4X Daughter card on each line card adds an additional 60Mpps of Forwarding performance.
Regards.
Wilson B.
