question??
wael azzam
Level 2
Level 2
Is there cisco  layer 2 Switches that can upgrade to L3 ???
shillings
Level 8
Level 8
Presume you're referring to a fixed-chassis switch. If so, then I'm not aware of any. The best you can do is buy a L3 switch with limited feature set - i.e. 3560-X with 'LAN Base' IOS.
You can configure some 2960 series switches to do limited static routing, but that doesn't make them an L3 switch to my mind.
Thanks so much  Shillings  for your help
