Question
desaivikesh1
Which statement about native VLAN traffic is true?
A. Cisco Discovery Protocol traffic travels on the native VLAN by default.
B. Traffic on the native VLAN is tagged with 1 by default.
C. Control plane traffic is blocked on the native VLAN.
D. The native VLAN is typically disabled for security reasons.
Which value is indicated by the next hop in a routing table?
A. preference of the route source
B. IP address of the remote router for forwarding the packets
C. how the route was learned
D. exit interface IP address for forwarding the packets
2 Accepted Solutions
AFROJ AHMAD
Answer to your ques: A. Cisco Discovery Protocol traffic travels on the native VLAN by default.
More details:
Vlan 1 can be the native Vlan (carry untaged traffic on trunks) or not
Any untagged traffic coming into the switch is assumed to be on vlan 1. if Native VLAN is 1 , you can change the native VLAN to VLAN 10 or any number.
****Vlan 1 cannot be deleted ( because transmits and receives packets from control protocols such as CDP, DTP, etc )
The routing table consists of at least three information fields:
  1. the network id: i.e. the destination subnet
  2. cost/metric: i.e. the cost or metric of the path through which the packet is to be sent
  3. next hop: The next hop, or gateway, is the address of the next station to which the packet is to be sent on the way to its final destination
Network id Cost Next hop
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
It is "NTP Master"
To configure the Cisco IOS software as a Network Time Protocol (NTP) master clock to which peers synchronize themselves when an external NTP source is not available, use the ntp master command in global configuration mode. To disable the master clock function, use the noform of this command.
Thanks-
Afroz
12 Replies 12
AFROJ AHMAD
More details:
Thanks-
Afroz
Thank you, I am sorry to disturb you, I have one more question,
Which NTP command configures the local device as an NTP reference clock source?
A.
ntp peer
B.
ntp broadcast
C.
ntp master
D.
ntp server
It is "NTP Master"
Thanks-
Afroz
Thank you
1: Which MTU size can cause a baby giant error?
A. 1500
B. 9216
C. 1600
D. 1518
Which statement about routing protocols is true?
A. Link-state routing protocols choose a path by the number of hops to the destination.
B. OSPF is a link-state routing protocol.
C. Distance-vector routing protocols use the Shortest Path First algorithm.
D. IS-IS is a distance-vector routing protocol.
Under which circumstance should a network administrator implement one-way NAT?
A.
when the network must route UDP traffic
B.
when traffic that originates outside the network must be routed to internal hosts
C.
when traffic that originates inside the network must be routed to internal hosts
D.
when the network has few public IP addresses and many private IP addresses require outside access
HI ,
Baby Giant frames are just slightly larger than the maximum size of an ethernet frame. Typically this means frames up to 1600 bytes in size.
2. OSPF is a link-state routing protocol.
3.when the network has few public IP addresses and many private IP addresses require outside access
Thanks-
Afroz
Hey man, are you sure about your answer for question 3? One-way nat implies question is about static NAT.  And your answer D is to use dynamic NAT. Shouldn't answer be B? When host inside is a server and all trafic from outside is translated to one IP?
I also think the answer is B.
Hi all,
I have one doubt about this question. I'm not quite sure about the differences between NTP Server and NTP Master, so I don't understand why in this case we must use NTP Master.
Would you mind to explain in short ?
Thank you.
desaivikesh1
what about second question?
Answer of your second Question:
Thanks-
Afroz
