queueing monitoring with 4000 and 6500
quesne02
Is there "easy" commands to monitor the queueing configured on 4000 series and 6500 series switches ?
We got some qos configured end to end and would like to revalidarte the settings configured.  What would be the best way to get the information about the drops packets per queue mapping and such.
dhristov
Please refer the software versions and the modules that you use.In general you can use:
On 6500:
"To see the queue structure of a LAN port, enter the show queueing interface {ethernet | fastethernet | gigabitethernet | tengigabitethernet} slot/port | include type command."
Reference:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html
On 4500 please note that there are difference between Sup 6E and previous releases:
show policy-map interface
show qos interface
Reference:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/qos.html
HTH,
-Dimitar
