Quick Fix Suggestion for Cisco 3850 Stack High Memory Issue
Hi Everyone,
I have two switches (SwitchA and Switch B) in stack configuration together. Recently we receive a High memory alert.
Upon checking, the slot which has high memory is only switch A (slot 1).
As  a quick fix, I am planning to reload only the slot 1.  (command: reload slot 1)
I would like to ask from your experience if this kind of approach will cause downtime.
Model:WS-C3850-24XS Software: 16.6.5
Switch A >> Master > Slot 1 (98% Memory Usage)
Switch B >> Standby > Slot 2 (50% Memory Usage
Or if anyone  jave suggestion how I can achieve no service interruption
Thanks for the help!
@dernucooper hello, according to the memory usage on both members, i suggest you to restart whole stack in planned downtime.
Good luck
KB
