Quick Question on N7K
Gents
One small question, can we connect ASA 5550 to Nexus 7K F2 module using twinax cable?
Thank You
Srikanth
Reza Sharifi
Yes, if you are usin 5585-X series
SFP-H10GB-ACU7M
10GBASE-CU SFP+ Cable 7 Meter, active
SFP-H10GB-ACU10M
10GBASE-CU SFP+ Cable 10 Meter, active
Here is the document:
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/5585guide/overview.html#wp1078820
Thanks for the information Bro.,
So conclusion is ASA5550 doesn't support this ... :-(
Correct, only the 5585-X series supports it.
Oh, BTW, the 5550 does not support 10Gig interfaces
