Quick question re lag groups
Process153
Level 3
Level 3
Hello!
Do hosts connected to Ethernet ports on say a 3750 that are part of a lag group share all the available bandwidth of the sum of the ports? So say 10 ports = 1000mb or am I misunderstanding the point of LAG's.
Thank you!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes and no.
Etherchannel provides an aggregate bandwidth increase, but individual flows will only use one link.
If there's more that one flow, those flows might use different links, avoiding contending for bandwidth on the same link.
How well multiple flows are spread across multiple flows, depends on your traffic's attributes and the distribution hashing algorithm being used.  (NB: BTW, a 3750's default hashing algorithm often should be changed, otherwise you might only see multi flow traffic using one link.)
Joseph W. Doherty
Disclaimer
Posting
Yes and no.
Thanks Joseph
