Quick Question - Trunking
dj214
How can you view which port(s) are designated trunk ports? On a 3524 xl, I set a port to trunk mode and doing sh int or sh run or sh vlan does not indicate anywhere that this port is in trunk mode.
thanks
Istvan_Rabai
Level 7
Level 7
Try "show interface trunk" or "show interface status"
Though it may happen that in these old switches these commands did not exist.
Cheers:
Istvan
neither worked. that seems crazy not to be able to determine which port is trunked.
Edison Ortiz
'show interface fx/x switchport'
HTH,
__
Edison
I'll give it a shot - thanks
