Quick UDLD Question
visitor68
Level 5
Level 5
Can you configure UDLD aggressive on one end and regular UDLD on the other?
Will the switches even accpet it..?
5 Replies 5
francisco_1
Level 7
Level 7
UDLD agressive inteoperates with UDLD normal on the other side of a link.
Francisco
OK, so the switches will allow this config.
However, in terms of functionality, the link will not truly be a UDLD aggressive link...it will fallback to UDLD....no?
I havent tested it myslef but i believe the link with agressive will stay that way and the other side normal. This type of configuration means that just one side of the link will be errdisabled once “Unidirectional” condition has been detected.
Francisco.
So if one side is agressive and the other side is normal, and the link is determined to be bi-directional and the UDLD information times out while the link on the port is still up, UDLD tries to re-establish the state of the port. If not successful, the port is put into the errdisable state on the aggressive side.
The bahavior of the normal mode, if the link state of the port was determined to be bi-directional and the UDLD information times out, no action is taken by UDLD. The port state for UDLD is marked as undetermined. The port behaves according to its STP state.
Francisco
ok, makes sense...thanks
