"ip helper" command on Nexus 5K
Munaf Ahmed
Are any of the following commands supported on Nexus 5K switches when deployed with L3 card:
  • ip helper address
  • ip forward-protocol
  • ip directed-broadcast
thanks
Munaf
rsimoni
Hi Munaf,
it is weird that a Cisco employee uses the public forum for these requests
anyway
  • ip helper address
    In NX-OS we use "ip dhcp relay address" command to relay the dhcp requests to a different subnet. It will work for DHCP requests only.
    not supported in NX-OS yet. Enhancement bug opened > CSCts96902    N5548 L3 support for "ip forward-protocol udp"    which is a dup of  CSCtj78445    NX-OS ER: allow any udp broadcast with ip helper-address just like IOS
    Feature already supported on N5k with L3. What is missing is the possibility to add an ACL. Also for this an enhancement bug has been opened > CSCts96910    N5548 L3 support for ACL in "ip directed-broadcast" command
regards,
Riccardo
rsimoni
Hi Munaf,
anyway
  • ip helper address
regards,
Riccardo
Munaf Ahmed
Thanks a lot for the answer.
