"test cable-diagnostics tdr" odd results
joebrug
Catalyst 2960-X switches running Version 15.2(3r)E1
Trying to track down why some devices are connected at 100mb instead of 1gb, like they should. So started using "test cable-diagnostics tdr interface gi1/0/1"
When device is plugged in, showing up/up at 100mb, I see the following result:
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/1 100M Pair A N/A N/A Not Completed
Pair B N/A N/A Not Completed
Pair C N/A N/A Not Completed
Pair D N/A N/A Not Completed
With cable unplugged on remote (user) end:
Gi1/0/1 auto Pair A 27 +/- 10 meters N/A Open
Pair B 28 +/- 10 meters N/A Open
Pair C 28 +/- 10 meters N/A Open
Pair D 1 +/- 10 meters N/A Open
This led me to attach a cable tester on both ends, which showed that the last pair was bad. After I fixed that, now I get:
Gi1/0/1 1000M Pair A 48 +/- 10 meters Pair A Normal
Pair B 48 +/- 10 meters Pair B Normal
Pair C 48 +/- 10 meters Pair C Normal
Pair D 48 +/- 10 meters Pair D Normal
Question is, why when connected @ 100mb, it shows Not Completed instead of telling me pair D is bad?
Leo Laohoo
Version 15.2(3r)E1
I think this is the ROMmon version.  I don't see 15.2(3r)E1 (not with an "r") in the Cisco download site.
2960X (and 3850) has a "strange" way of implementing TDR.  If there is a fault in any of the pair, the distance will be displayed.  If there entire length has no fault, then the distance will be displayed as "0".
The "accuracy", however, is something else.  Unlike the "older" 2960S, I recently found the accuracy of the 2960X TDR to be "questionable" at best.
My recommendation is to raise a Cisco TAC Case so that the developers may (a statement of probability) improve the TDR's function.
Don't ask me why, that's just how it was "implemented".
Sorry, you're right, I posted the wrong thing:
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E3
I have to agree with Leo on the accuracy of the test on the 2960X.
On the 2960S results were usually pretty good. The 2960X results has just recently cost me a big chunk of personal reputation. For example, the below test is run on a 48 port 2960X running LANBase version 15.2(2)E5 with Bootloader 15.2(3r)E1. The cable was a straight-through 2 meter CAT5, the AP connected is a lightweight 1832i V3 and the local controller (not that it is relevant) is a 2504 with 8.5 firmware. Check the pair lengths and pair to pair readings
2960X-Gigabit#sho cable-diagnostics tdr int gig 1/0/2
TDR test last run on: March 30 18:21:15
Gi1/0/2   1000M Pair A     28   +/- 10 meters Pair B      Normal
                Pair B     28   +/- 10 meters Pair A      Normal
                Pair C     28   +/- 10 meters Pair D      Normal
                Pair D     28   +/- 10 meters Pair C      Normal
That's really quite poor! To compare I ran the same test on an older Gigabit 2960S running LANBase 12.2(55)SE5 with bootloader 12.2(55r)SE
Lab-Sw-2960S#sho cable-diagnostics tdr int gig 1/0/2
TDR test last run on: March 01 00:06:59
Gi1/0/2   1000M Pair A     2    +/- 0  meters Pair A      Normal
                Pair B     2    +/- 0  meters Pair B      Normal
                Pair C     2    +/- 0  meters Pair C      Normal
                Pair D     2    +/- 0  meters Pair D      Normal
That's much more like it. Ignore the date there is no NTP server configured for the 2960S.
What has gone so badly wrong with this test from 2960S to 2960X?
Ho1y sh1t! That's one big, bad discrepancy.
My recommendation is to raise a TAC Case (make sure you involve your SE) and get them to investigate this as a bug.
Be warned that the Cat 2K is the "economy" version of the more expen$ive Cat3K and Cat9K. So please don't be disheartened when TAC or developers are/doesn't sound "interested" with this find.
