Rackmount kit for C3750G-24WS-S25
jsachnet1
I am looking for the rack mount part number for a WS-C3750G-24WS-S25. This switch has the built in wireless lan controller and is 2U. I have only been able to find the 1U and 1.5U rack mounts but not the 2U for this specific switch. Picture is attached of what the rackmounts look like for this switch but I am unable to read the part number or find the part number anywhere.
7 Replies 7
JP Babiera
Level 4
Level 4
Ooh, I remember having that 3750 with the integrated WLC.  I think that may be 1.5U and might be a RCKMNT-3750-1.5RU.
Maybe these could help you steer in the right direction:
https://supportforums.cisco.com/discussion/10871996/ws-c3750g-24ws-s25-rack-mounts
http://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-3750-series-integrated-wireless-lan-controllers/product_data_sheet0900aecd804b0879.html
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/hardware/installation/guide/3750hig/HIGINSTL.html#wp1344882
HTH,
JP
The switch is definitely 2U as it is 3.5" tall. I went through and looked at every rack mount kit on cableandkits website and did not see a bracket that looks like the one from the picture I posted. You can tell that the 1.5U bracket probably will not work as it is too small. I did find one that may work with another hole drilled.
http://www.cablesandkits.com/cisco-2900m-series-rack-mount-kit-p-40.html?utm_source=amazon&utm_medium=cpc&utm_term=STK-RACKMOUNT-2RU&utm_campaign=Cisco%20Rack%20Mount%20Kits
I see, have you thought about getting a shelf instead? Since the mount kit seems to be a hit or miss.
*EDIT* nevermind, this seems like a bad idea.
I went ahead and bought the 2900 series 2RU rackmounts. Will see if they work and if any modifications are necessary.
Here's just a few of the collection i've gathered in the past few months from decommissioning gear. Even got a massive 3-RU in there!
jhager001
"For the Catalyst 3750G-24TS switch, order part number RCKMNT-3550-1.5RU=. For the other Catalyst 3750 switches, order part number RCKMNT-1RU=. The Catalyst 3750G-24WS-S25 and the 3750G-24WS-S50 switch do not support 24-inch rack-mounting."
you can check here for different types of Rack Mount kits
http://www.cablesandkits.com/cisco-rackmount-kits-c-232_24.html
most likely going to be this one
http://www.cablesandkits.com/cisco-3750g-series-15ru-rack-mount-kit-p-108.html
