radius and autentication methods
sarahr202
Level 7
Level 7
Hi everybody
Does Radius protocol only support 802.1x authentication?
thanks and have a great day.
yes of course you can use it for login authentication or PPP authentication for example.
Regards.
Alain
Reza Sharifi
Hi Sarah,
Yes, If you are deploying 802.1x, you would need Radius for authentication.
Thanks Reza
but if i am not depoying 802.1x can i still use radius protocol? or To put it another way  Is Raduis protocol only used for 802.1x authentication?  Can we use Radius protocol with other authentication methods?
Regards.
Alain
Thanks Alain
