04-15-2025 04:12 AM - edited 04-16-2025 04:17 AM
i'm using C1300-24P-4X-Switches with 802.1X-Authentication against NPS on a Windows Server 2022-Server.
After updating the Cisco firmware from 4.1.4.1 to 4.1.6.64 the Radius-Authentication with computer certificates isn't working anymore; in the NPS-Log, i'm getting this error:
Reason Code: 16 Authentication failed due to a user credentials mismatch. Either the user name provided does not map to an existing user account or the password was incorrect
I'm sure, that the NPS-Server is working as expected, because our WiFi is also using 802.1X against the same NPS-Server without any problem. Also, only the firmware update of the switches changed since yesterday.
If a user could't be authenticated, it gets a guest vlan assigned. Thats actual the case for all users/ports.
I checked the Release-Notes from Cisco (Release Note for Cisco Catalyst 1200 and 1300 Series Switches Firmware Version 4.0.0.91 - 4.1.6.54); there's a info, that some Radius-behaviour has changed. As i understand, the "Message-Authenticator attribute" was added and is disabled by default. I've enabled and disabled it for testing without any success.
Has anybody an idea, what's the cause for this problem? I don't find any errors in the configuration
This is the running configuration; i've replaced sensitive data with "xxx":
v4.1.6.54 / RLSB4.1.6_951_410_024 CLI v1.0 file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end xxx ! ! unit-type-control-start unit-type unit 1 network gi uplink te unit-type unit 2 network gi uplink te unit-type unit 3 network gi uplink te unit-type unit 4 network gi uplink te unit-type unit 5 network gi uplink te unit-type unit 6 network gi uplink te unit-type unit 7 network gi uplink te unit-type unit 8 network gi uplink te unit-type-control-end ! port jumbo-frame vlan database vlan xxx exit voice vlan oui-table add 0001e3 Siemens_AG_phone voice vlan oui-table add 00036b Cisco_phone voice vlan oui-table add 00096e Avaya voice vlan oui-table add 000fe2 H3C_Aolynk voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone voice vlan oui-table add 00e075 Polycom/Veritel_phone voice vlan oui-table add 00e0bb 3Com_phone dot1x system-auth-control dot1x mac-auth radius bonjour interface range vlan 1 hostname xxx line console exec-timeout 30 exit encrypted radius-server host xxx key xxx priority 1 encrypted radius-server host xxx key xxx priority 2 aaa accounting dot1x start-stop group radius username admin password encrypted xxx privilege 15 ip ssh server ip ssh logging enable ip ssh password-auth ip http timeout-policy 0 clock timezone CET +1 sntp server xxx poll sntp server xxx poll no sntp server pool.ntp.org no sntp server time-a.timefreq.bldrdoc.gov no sntp server time-b.timefreq.bldrdoc.gov no sntp server time-c.timefreq.bldrdoc.gov no sntp server time-pnp.cisco.com ip domain name xxx ip name-server xxx xxx no pnp enable cbd probe enable cbd address xxx encrypted cbd key id xxx secret xxx cbd connection enable ! interface GigabitEthernet1/0/1 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C12 ! interface GigabitEthernet1/0/2 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description "C5" ! interface GigabitEthernet1/0/3 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B12 ! interface GigabitEthernet1/0/4 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B13 ! interface GigabitEthernet1/0/5 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B6 ! interface GigabitEthernet1/0/6 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B7 ! interface GigabitEthernet1/0/7 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C7 ! interface GigabitEthernet1/0/8 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C11 ! interface GigabitEthernet1/0/9 dot1x radius-attributes vlan static description "C8" ! interface GigabitEthernet1/0/10 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/11 description "C6" ! interface GigabitEthernet1/0/12 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/13 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B24 ! interface GigabitEthernet1/0/14 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B19 ! interface GigabitEthernet1/0/15 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description D13 ! interface GigabitEthernet1/0/16 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description B18 ! interface GigabitEthernet1/0/17 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description D14 ! interface GigabitEthernet1/0/18 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/19 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/20 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/21 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/22 dot1x radius-attributes vlan static description "B22" switchport access vlan xxx ! interface GigabitEthernet1/0/23 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet1/0/24 description xxx switchport mode trunk switchport general allowed vlan add xxx tagged switchport trunk allowed vlan xxx ! interface TenGigabitEthernet1/0/1 description xxx switchport mode trunk switchport trunk allowed vlan xxx ! interface TenGigabitEthernet1/0/2 switchport mode trunk ! interface GigabitEthernet2/0/1 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C1 ! interface GigabitEthernet2/0/2 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description D6 ! interface GigabitEthernet2/0/3 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description D7 ! interface GigabitEthernet2/0/4 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description D9 ! interface GigabitEthernet2/0/5 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/6 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description D8 ! interface GigabitEthernet2/0/7 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/8 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/9 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/10 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/11 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/12 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/13 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C15 ! interface GigabitEthernet2/0/14 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C16 ! interface GigabitEthernet2/0/15 dot1x radius-attributes vlan static description "C24" ! interface GigabitEthernet2/0/16 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C23 ! interface GigabitEthernet2/0/17 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C22 ! interface GigabitEthernet2/0/18 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description C21 ! interface GigabitEthernet2/0/19 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/20 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto ! interface GigabitEthernet2/0/21 dot1x guest-vlan enable dot1x reauthentication dot1x radius-attributes vlan static switchport access vlan 11 ! interface GigabitEthernet2/0/22 dot1x guest-vlan enable dot1x reauthentication dot1x radius-attributes vlan static switchport access vlan 11 ! interface GigabitEthernet2/0/23 dot1x guest-vlan enable dot1x reauthentication dot1x authentication 802.1x mac dot1x radius-attributes vlan static dot1x port-control auto description "E4" ! interface GigabitEthernet2/0/24 dot1x radius-attributes vlan static description xxx switchport mode trunk switchport general allowed vlan add xxx tagged switchport trunk allowed vlan xxx ! interface TenGigabitEthernet2/0/1 description xxx switchport mode trunk switchport trunk allowed vlan xxx ! interface TenGigabitEthernet2/0/2 switchport mode trunk switchport trunk allowed vlan xxx switchport trunk allowed vlan add xxx switchport trunk allowed vlan add xxx ! exit interface bluetooth 0 shutdown ! ip default-gateway xxx
Edit 1:
I'm not sure, but... the complete NPS-Log-Entry for the deny:
Der Netzwerkrichtlinienserver hat einem Benutzer den Zugriff verweigert. Wenden Sie sich an den Administrator des Netzwerkrichtlinienservers, um weitere Informationen zu erhalten. Benutzer: Sicherheits-ID: NULL SID Kontoname: xxxxxf5f441 Kontodomäne: xxx Vollqualifizierter Kontoname: xxx\xxxxxf5f441 Clientcomputer: Sicherheits-ID: NULL SID Kontoname: - Vollqualifizierter Kontoname: - ID der Empfangsstation: xxx ID der Anrufstation: xxx NAS: NAS-IPv4-Adresse: xxx NAS-IPv6-Adresse: - NAS-ID: - NAS-Porttyp: Ethernet NAS-Port: 69 RADIUS-Client: Clientanzeigename: xxx Client-IP-Adresse: xxx Authentifizierungsdetails: Name der Verbindungsanforderungsrichtlinie: 802.1X Ethernet Netzwerkrichtlinienname: - Authentifizierungsanbieter: Windows Authentifizierungsserver: Domain controller Authentifizierungstyp: PAP EAP-Typ: - Kontositzungs-ID: 3035303030303532 Protokollierungsergebnisse: Die Kontoinformationen wurden in die lokale Protokolldatei geschrieben. Ursachencode: 16 Ursache: Authentifizierungsfehler aufgrund der Nichtübereinstimmung von Benutzeranmeldeinformationen. Der angegebene Benutzername ist keinem vorhandenen Benutzerkonto zugeordnet, oder das Kennwort war falsch.
This looks like a error message regarding a MAC-based authentication. If i look into the older logs with success-messages, they contain the Hostname of the client, which tried to authenticate with 802.1X:
Der Netzwerkrichtlinienserver hat einem Benutzer den Zugriff gewährt. Benutzer: Sicherheits-ID: xxx\HOSTNAME$ Kontoname: host/hostname.domain.tld Kontodomäne: Domain Vollqualifizierter Kontoname: domain\HOSTNAME$
I already disabled the MAC-based authentication on my Test-Networkport; but i sill getting errors that look like the first one above.
Edit 2: Here's the error-message logged by the switch for the failed authentication:
%SEC-W-SUPPLICANTUNAUTHORIZED: MAC xxx was rejected on port gi2/0/17 due to wrong user name or password in Radius server
Edit 3: I'm very consufed. I switched back to firmware 4.1.4.1 and applied a configuration backup, which was taken with 4.1.4.1: I still can't authenticate with 802.1X. I've checked the windows updates on client/server; no updates we're installed in the time range, i've updated the switches. Also, i've rebootet our primary Radius-Server (DC) without success. Any suggestions?
04-18-2025 03:57 AM
Are this issue solved?
MHM
04-21-2025 11:49 PM
Hello MHM,
no, the problem still exists. I don't have further ideas, what's the cause for this issue.
On the last weekend, i've resettet a Stack of four Catalyst 1300-Switches, with 4.1.6.64 already installed and configured them from scratch.
The 802.1X is still not working (with the described error messages). I'm absolute not sure, what i should do next. The NPS-Servers are working still fine with our Ruckus-WLAN and 802.1X.
I know, that this problem seems curious and the switches and the firmware update should not be the cause, because if i switch back to 4.1.4.1 and the old config file, it's still not working. But i didn't change other settings in NPS, DCs, Roles, GPOs, etc.
I also checked things like the CA Certificate expiration, that the clients have valid computer certificates, matched the running configuration for 802.1X (GPOs, NPS-Settings, PSKs, etc.) against our documentation - but they are all correct. That 802.1X is working with the WiFi-Environment shows, that there can't be a gross mistake.
Do you have any ideas, how i could troubleshoot this issue further?
Thanks in advance,
Bastian
05-15-2025 02:58 AM
i think, i found the cause. If Jumbo frames are activated on the Switch, 802.1X is not working. After i deactivate them, 802.1x works like before.
I will troubleshoot further and reply to this post, if i have more information.
