Device management on CISCO Catalyst Center
Saud Alpha
Hi All
Customer is currently using Cisco Prime infrastructure and looking to replace it with on-premises Monitoring solution.
I need clarity that Is it possible to support below devices on CISCO Catalyst Center (formerly Cisco DNA Center), If yes than what is license requirement for Nexus, Firepower, FMC, and CISCO legacy devices.
3rd party Devices:
Palo Alto Firewall
Fortinet Firewall
Mivoice 3300 Controller
Legacy CISCO Devices:
AIR-AP1562I-M-K9
CISCO 2900 Series Switch Models
CISCO 3600, 3700 and 3800 Switch Models.
CISCO Nexus Switches and CISCO Firewall:
C93180YC-FX Chassis
Cisco FMC 1600
Cisco Firepower 4112 Threat Defense
Leo Laohoo
Cisco DNAC will never (ever) support 3rd party appliances.
Saud Alpha
Thanks for replying. Can you refer below URL and reconfirm. Appreciate your support and time.
https://community.cisco.com/t5/networking-knowledge-base/faq-catalyst-center-third-party-device-visibility/ta-p/4910315
As the first line of that doc lists "Yes, Catalyst Centre support Third Party devices which are capable of retrieving MIB-II data compliant with RFC1213", so limited information can be pulled from the third party device if they fulfill this requirement. The support for these devices is not likely to improve.
For the remaining devices you will have to refer to the compatibility matrix to see what features are supported for the devices: https://www.cisco.com/c/dam/en/us/td/docs/Website/enterprise/catalyst_center_compatibility_matrix/index.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
