Radius Authentication
Arun Kumar Thakur
Frequent Visitor
Frequent Visitor
I am trying to configure 802.1x RADIUS Authentication on cisco 2950-24TT-L Switch. I am using following set of command as given below
Switch# configure t
Switch(config)# aaa new-model
Switch(config)# aaa authentication dotx default group redius
Switch(config)# dot1x system-auth-control
Switch(config)# inter fasteth 0/1
Switch(config)#dot1x port-control atuo
I am faceing problem dot1x command is not working on interface. Kindly help me.
Amarjeet Singh
Chandigarh
cadet alain
int f0/1
switchport mode access
dot1x port-control auto
Alain
Hi, cadet
Thanks for your replay!
It works and before I key in "dot1x port-control auto".
The running-configure shows the int is "authentication port-control auto".
But it works, thanks!
