Radius communication
I would like to setup a Catalyst IOS switch to communicate with a RSA Securid Radius server using the Radius protocol? Can someone please tell me the command to do this?
I appreciate any help?
Lake
IAN WHITMORE
Level 4
Level 4
Try looking at the command reference for your switch. The commands themselves are not difficult, but there are quite a lot depending what you need (authorisation, accounting, vendor specific stuff). Here's the reference for a Cisco 3750:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swauthen.html#wp1091260
I can't recommend strongly enough going through the documentation though.
And whatever you do, don't lock yourself out of the switch!
HTH,
Ian
IAN WHITMORE
Level 4
Level 4
HTH,
Ian
Thank you very much
