radius is not functioning with fastethernet0 on 2960X
SMD28316
This is a follow up to my question here:
https://community.cisco.com/t5/switching/fast-ethernet-0-fails-as-a-radius-source-interface/td-p/4466414
I checked the NPS server (radius server), I can see that it receives access-request, and sends access-challenge so reachability isn't an issue, but I see no response back from the problematic 2960X switch to the access challenge, here is the packet capture from NPS server:
1 0.000000 __SW_IP___ __NPS_IP___ RADIUS 336 Access-Request id=69
2 0.007825 __NPS_IP___ __SW_IP___ RADIUS 132 Access-Challenge id=69
3 0.022065 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=70
4 0.034445 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2586) [Reassembled in #5]
5 0.034445 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=70
6 5.039077 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=70, Duplicate Request
7 5.039468 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2587) [Reassembled in #8]
8 5.039468 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=70, Duplicate Response
9 10.100604 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=70, Duplicate Request
10 10.101052 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2588) [Reassembled in #11]
11 10.101052 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=70, Duplicate Response
12 15.139430 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=70, Duplicate Request
13 15.139846 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2589) [Reassembled in #14]
14 15.139846 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=70, Duplicate Response
15 20.156202 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=70, Duplicate Request
16 20.156567 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=258a) [Reassembled in #17]
17 20.156567 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=70, Duplicate Response
18 29.019876 __SW_IP___ __NPS_IP___ RADIUS 336 Access-Request id=71
19 29.024155 __NPS_IP___ __SW_IP___ RADIUS 132 Access-Challenge id=71
20 29.033635 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=72
21 29.035850 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=258c) [Reassembled in #22]
22 29.035850 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=72
23 34.096709 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=72, Duplicate Request
24 34.097089 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=258d) [Reassembled in #25]
25 34.097089 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=72, Duplicate Response
26 39.136073 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=72, Duplicate Request
27 39.136460 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=258e) [Reassembled in #28]
28 39.136460 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=72, Duplicate Response
29 44.173830 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=72, Duplicate Request
30 44.174227 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=258f) [Reassembled in #31]
31 44.174227 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=72, Duplicate Response
32 47.041264 __SW_IP___ __NPS_IP___ RADIUS 336 Access-Request id=73
33 47.045507 __NPS_IP___ __SW_IP___ RADIUS 132 Access-Challenge id=73
34 47.060580 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=74
35 47.062646 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2591) [Reassembled in #36]
36 47.062646 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=74
37 49.214090 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=72, Duplicate Request
38 49.214560 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2592) [Reassembled in #39]
39 49.214560 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=72, Duplicate Response
40 52.093857 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=74, Duplicate Request
41 52.094240 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2593) [Reassembled in #42]
42 52.094240 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=74, Duplicate Response
43 54.577225 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
44 54.577369 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
45 54.577508 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
46 57.119618 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=74, Duplicate Request
47 57.120034 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2594) [Reassembled in #48]
48 57.120034 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=74, Duplicate Response
49 62.137343 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=74, Duplicate Request
50 62.137738 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2595) [Reassembled in #51]
51 62.137738 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=74, Duplicate Response
52 65.093093 __SW_IP___ __NPS_IP___ RADIUS 336 Access-Request id=75
53 65.097385 __NPS_IP___ __SW_IP___ RADIUS 132 Access-Challenge id=75
54 65.104595 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=76
55 65.106749 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2597) [Reassembled in #56]
56 65.106749 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=76
57 67.175741 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=74, Duplicate Request
58 67.176147 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2598) [Reassembled in #59]
59 67.176147 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=74, Duplicate Response
60 70.134165 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=76, Duplicate Request
61 70.134557 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=2599) [Reassembled in #62]
62 70.134557 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=76, Duplicate Response
63 75.177515 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=76, Duplicate Request
64 75.177919 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=259a) [Reassembled in #65]
65 75.177919 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=76, Duplicate Response
66 80.210855 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=76, Duplicate Request
67 80.211273 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=259b) [Reassembled in #68]
68 80.211273 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=76, Duplicate Response
69 83.118317 __SW_IP___ __NPS_IP___ RADIUS 336 Access-Request id=77
70 83.123099 __NPS_IP___ __SW_IP___ RADIUS 132 Access-Challenge id=77
71 83.137886 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=78
72 83.140758 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=259d) [Reassembled in #73]
73 83.140758 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=78
74 85.237107 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=76, Duplicate Request
75 85.237468 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=259e) [Reassembled in #76]
76 85.237468 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=76, Duplicate Response
77 88.175269 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=78, Duplicate Request
78 88.175629 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=259f) [Reassembled in #79]
79 88.175629 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=78, Duplicate Response
80 93.214901 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=78, Duplicate Request
81 93.215359 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=25a0) [Reassembled in #82]
82 93.215359 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=78, Duplicate Response
83 98.253634 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=78, Duplicate Request
84 98.254141 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=25a1) [Reassembled in #85]
85 98.254141 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=78, Duplicate Response
86 103.292315 __SW_IP___ __NPS_IP___ RADIUS 512 Access-Request id=78, Duplicate Request
87 103.292790 __NPS_IP___ __SW_IP___ IPv4 1514 Fragmented IP protocol (proto=UDP 17, off=0, ID=25a2) [Reassembled in #88]
88 103.292790 __NPS_IP___ __SW_IP___ RADIUS 152 Access-Challenge id=78, Duplicate Response
89 114.572690 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
90 114.572776 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
91 114.572951 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
92 114.573089 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
93 114.573229 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
94 174.568841 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
95 174.570003 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
96 174.571046 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
97 174.572213 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
98 174.573364 __SW_IP___ __NPS_IP___ ICMP 70 Time-to-live exceeded (Fragment reassembly time exceeded)
There are so may duplicate requests, and TTL messages sent from the switch to the NPS server, below is the content of ICMP messages:
Internet Control Message Protocol
    Type: 11 (Time-to-live exceeded)
    Code: 1 (Fragment reassembly time exceeded)
    Checksum: 0xf004 [correct]
    [Checksum Status: Good]
    Unused: 00000000
    Internet Protocol Version 4, Src: NPS_IP , Dst: SW_IP
    User Datagram Protocol, Src Port: 0, Dst Port: 1479
        Source Port: 0
        Destination Port: 1479
        Length: 0 (bogus, must be >= 8)
            [Expert Info (Error/Malformed): Bad length value 0 < 8]
                [Bad length value 0 < 8]
                [Severity level: Error]
                [Group: Malformed]
Two things I noticed for the working and non working switches:
  1. I can't ping NPS server with MTU Size of 1500 from fa0 on the problematic switch.
  2. Fa0 on the problematic switch has 0 hits in cache, unlike the working one.
    FastEthernet0-Physical buffers, 1524 bytes (total 32, permanent 32):
          24 in free list (0 min, 32 max allowed)
          8 hits, 0 fallbacks
          8 max cache size, 8 in cache
    -     0 hits in cache, 0 misses in cache
    +     70223883 hits in cache, 0 misses in cache
Why is this difference since both switches have the same configuration and same MTU size (globally and under Fa0)?
not sure if your previous post already contains this, but can you post the full running configuration of the 2960X ?
