Pole switches ........cannot SSH(Connection Refused)
khaja1989
Community Member
Hello Team,
I cannot ssh some pole switches in my customer network,i can ping those devices but cannot ssh those device when i ssh those devices it says connection refused,,what should be the fix,or my plan of attack.
khaja
8 Replies 8
Mark Elsen
          - What is  a pole switch ? Which models are involved ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
thanks for the response,
i check other pole switch where i am able to ssh to check model.......Switch Ports Model SW Version SW Image
* 1 10 WS-C3560C-8PC-S 12.2(55)EX3 C3560c405-UNIVERSALK9-M,
so its this model,so need to find out why in my network i cannot ssh other switches,any clue,thoughts,solutions
 - Check this document as to how configure SSH on the switch :
              https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960cx_3650cx/software/release/15-2_3_e/configuration/guide/b_1523e_consolidated_2960cx_3560cx_cg/b_consolidated_152ex_2960-X_cg_chapter_0101000.pdf
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi below is my output for the device which i cannot ssh can you let me know if you find anything
TTILGB_3560_Pole_LW01#show running-config
Building configuration...
Current configuration : 3792 bytes
version 12.2
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname TTILGB_3560_Pole_LW01
logging buffered 65536 debugging
enable secret 5 $1$/.FA$klQSXMUI8HKETSTslaJdu0
username Lake2Lake password 7 02121052590A0E2A49
aaa new-model
aaa authentication login default group radius local
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
system mtu routing 1500
vtp domain TTI
vtp mode transparent
ip subnet-zero
no ip domain-lookup
mls qos
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 2
name Management-Vlan
vlan 4-5
vlan 22
name IP-Readers-Servers-Vlan
vlan 72
name Video-Application-Vlan
interface FastEthernet0/1
switchport access vlan 5
switchport mode access
mls qos trust dscp
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 4
mls qos trust dscp
interface FastEthernet0/3
mls qos trust dscp
interface FastEthernet0/4
mls qos trust dscp
interface FastEthernet0/5
mls qos trust dscp
interface FastEthernet0/6
mls qos trust dscp
interface FastEthernet0/7
mls qos trust dscp
interface FastEthernet0/8
mls qos trust dscp
interface GigabitEthernet0/1
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.200.1.222 255.255.255.0
ip default-gateway 10.200.1.10
ip classless
ip http server
ip radius source-interface Vlan2
logging trap notifications
logging 10.200.130.51
access-list 10 permit 10.200.1.100
snmp-server community lake RO
snmp-server community DPSNMPG3T! RO
snmp-server location TTI Long Beach, CA
snmp-server contact LakeSystems
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps power-ethernet group 1
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps mac-notification
snmp-server enable traps config-copy
snmp-server enable traps hsrp
snmp-server enable traps rtr
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
snmp-server host 10.200.100.49 version 2c DPSNMPG3T!
snmp-server host 10.200.1.100 lake
tacacs-server host 10.200.101.211
tacacs-server directed-request
tacacs-server key 7 051A141B2F495A5B
radius-server host 10.200.130.32 auth-port 1645 acct-port 1646
radius-server source-ports 1645-1646
radius-server key 7 071B3545420E1B4B19171F1B0B38206A79636772
control-plane
line con 0
password 7 140306025E082B2021
line vty 0 4
privilege level 15
password 7 051F120673404F021C
line vty 5 15
ntp clock-period 36028777
ntp server 192.168.27.10
end
 - You have not made any modifications according to the document I send you earlier. Please take action.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks for the response,
yes just wanted to show the output before i make change ,,,,,so ssh not configured correct
Hello
Try Telnet instead.
Kind Regards
Paul
hi paul,
thanks for the response,yes i am able to telnet the devices but my manager asked my that why i cannot ssh the device ......so i posted the output to see if we can figure out may be ssh not configured.
shakeebuddin khaja
