PoE issue on a Cat2960L switch
Hi All,
I'm having a weird issue with one of my cat-2960L switches. PoE is not powering up one of our Cisco Phones. this is where is gets odd, I can take another similiar mode phone and it works in that port and move the phone that's not working to another port and it works. Here's a list of trouble shooting I've done and the results.
* Patch Fluke linkrunner in to switch port and run auto test, shows PoE and the watts, supported be log entries while running 'debug ilpower event'
* repeat test with phone that's not working, phone doesn't power up and no events in logs on switch.
* swap phone to another port that has a phone and it works, as well we moved the phone that was in the test port to the port we're having issues with and that phone works.
* we have approximately 4 ports showing the same symptoms.
* I've tried disable PoE on the ports we're having issues with and then enabling it - no effect.
* Since we're patching directly into the switch with a 3' cable it's not distance.
* show power inline , shows we still have 216.8(w) and the ports are set to auto
Any thoughts?
JT
6 Replies 6
marce1000
 - Review these bug reports, check if anything might be applicable to you case :
               https://bst.cloudapps.cisco.com/bugsearch/search?kw=2960L%20poe&pf=prdNm&sb=anfr
  Note  : when pressing the link, it may take a few seconds, before the bug-list appears.
 M.
marce1000
 (sanity-check , sorry if seen twice)
 M.
Nothing specifically matched, but I tried using the 'power inline never' command. - no effect. I'm going to check with some of the other debug ilpower commands.
What is the exact model of the switch?
LAN Lite switches only provide PoE to the first 8 ports.
Leo Laohoo
Post the complete output to the command "sh post".
10EAR-SW1#sh post
Stored system POST messages:
Switch 1
POST: Thermal Tests : Begin
POST: Thermal Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
