RADIUS Issues c9300
abarb002
So I just inserted a new c9300 switch onto the network. Everything seems to be working fine. I am able to ssh into the switch not having such luck with RADIUS. I am getting a Audit Success in the Security log of the server, but I get the following message on the switch:
Sec_login_FAILED: Login failed (user invalid-credentials (source laptop) (local 22) reason: login authentication failed)
I know port 22 is ssh, but in my configs I do have 1812 listed as the radius port. I can't post my configs for security reasons.
Any suggestions on how to tackle this?
I use the same credentials for all devices.
I discovered the problem. I fat fingered the switch ip address in the OSPF configurations, therefore the switch was unknown to the network and could not be authenticated. So a mis-configured ip in area 1 of the ospf was the problem.
Thanks for you help.
5 Replies 5
Reza Sharifi
Have a look at this link. Not sure you have the same issue but resetting the RSA key seems to have fixed this for someone here.
UDP  port 1812 is the correct, default radius port.
https://community.cisco.com/t5/network-management/login-on-failure-log-message-problem/td-p/3335410
No, this did not work. I am still getting a invalid credentials source laptop IP on port 22.
My Radius settings are:
aaa authentication login INSIDE local-case group radius
aaa authentication login *access-list* group radius local-case
aaa authorization exec defulat group radius local if authenticated
radius server *name*
 address ip4 ip# auth-port 1812 acct-port 1813
 key 7 #############################
line vty 04
 access-class acl in
 access-class acl out
login authentication acl name
transport ssh
thoughts
What if you remove the ACLs and test again?
no  access-class acl in
no  access-class acl out
balaji.bandi
Adding to other post - check on the radius server log also cross verification.
BB
