RAP/MAP with VLAN Issue
marcrichards
Frequent Visitor
Frequent Visitor
I am having an issue with a MAP/RAP setup that I have delivering to one of our sites.  Seems I cannot find the working combination of the Access/Voice VLANs and Management VLAN (better explanation to follow).  To start with I want to give an overview of what gear I'm using.  At Site A I have a Catalyst 3650 (Denali Version 16.3.7) connected to a Nexus 7K (6.2(20a)) by fiber to our HQ (trunk/vtp-enabled).  On the 3650 at Site A on a Gig/E interface I am connected to an AP1572EAC, serving as the RAP ('switchport trunk native vlan 10' for this interface on the switch) so that the AP can get an IP and have an L3 path back to the controller (redundant 5520's code is 8.5.135.0).  On the far side at Site B I have matching AP1572EAC connecting to a Cat. 2960CX (switchport trunk native vlan 10).
On the access point at Site A in the Mesh tab, Ethernet Bridging, and the Gig/E interface that is connected to the switch I have the Mode set to Trunk, Native VLAN Id 10 and allowed VLANs 10, 200, 300, etc.. On the access point at Site B in the Mesh tab, Ethernet Bridging, and the Gig/E that is connected to the switch I have the Mode set to Trunk, Native VLAN Id 10 and the same set of allowed VLANs.
Now that we have the basic setup out of the way my issue is that at Site B I can have one or the other, but not both;  Management, or happy users (phones and computers work / access vlan 200, voice vlan 300).  Obviously we chose happy users since this site is only a mile or so away.  The management is on interface VLAN 10 (which yes is the native vlan) for all devices in our network, the switch at Site B being no exception.  To get management but not access/voice vlan connectivity, I can change the native VLAN on both the MAP and RAP to 1. Additional detail: Not sure of the relevancy but we do have a trunk going to another switch at Site B.  I do not have an IP conflict with any of the management network devices.
Configuration Snippets to follow...
Site A Gig/E to the RAP:
description TRUNK LINK to SITE A RAP
switchport mode trunk
spanning-tree bpduguard disable
Site A 10Gig/E to Nexus:
description TRUNK to HQ
Site B Gig/E to the MAP:
description TRUNK LINK to SITE B MAP
Site B Management Interface:
interface Vlan10
description Network_Management
ip address 10.0.0.XX 255.255.255.0
Site B Link to other switch:
interface Port-channel1
interface GigabitEthernet0/7
description PAgP Link to SITE B Switch 2
channel-group 1 mode auto
interface GigabitEthernet0/8
I hope the above are enough details to help!
Hello
So are just wireless users  having issues connecting to the mgt vlan or wired also?
I am assuming looking at the config youve posted that the 7K is perfroming the intervlan routing for both sites?
Are you using any fabric extenders?
How are you trying to connect to the mgt vlan and where from, does it work from anywhere in the estate?
Can you post the config of the 7K and site A/Bs accesss switches if applicable and maybe a simple toplogy of your network
Kind Regards
Paul
So, not so much wireless users as much as it is a site being fed over wireless.  The 7K is performing interVLAN routing for the entire network.  Attached is a quick and dirty diagram of the scenario at hand and also the config of the Site B switch.  The config of the Nexus is not quiet relevant since the VLANs are correctly configured and the hardwired fiber sites (all 8 of them) are working perfectly. In the present state I cannot ping EITHER site B switch.  I can ping and have established full connectivity to the phones and PCs located at Site B on VLANs 203 and 300 (I think I said Vlan 200 above, which was in error).  NetworkDiagramRev1.jpg
