Rapid ping vrf
sassi-zied
Community Member
Hi all,
Is there any possibility to do a rapid ping vrf in Cisco. I found the pramater repeat but is this a rapid ping ? if so what is the ping interval ? Can we change it ? For exemple in Juniper or Alcatel we can find the parameter "rapid" i can't find it in Cisco. My goal is to do a ping with an interval (between each paket ) of 20 ms. Is it possible ?
Zied
In cisco world a rapid ping is using timeout 0. something like this ping repeat 10000 timeout 0
This will flood the link without waiting for a reply .
repeat in cisco devices is the same as count on junipers.
Hope this is what you are looking for
Kishore
6 Replies 6
John Blakley
I don't think it's possible to change the time interval between icmp packets on a Cisco device. The pings seem to be 1ms apart.
HTH,
John
HTH, John *** Please rate all useful posts ***
Kishore
Kishore,
That's an interesting concept:
R2#ping 10.1.12.1 timeout 20 rep 500
Sending 500, 100-byte ICMP Echos to 10.1.12.1, timeout is 20 seconds:
Success rate is 100 percent (500/500), round-trip min/avg/max = 1/4/32 ms
R2#ping 10.1.12.1 timeout 0 repeat 500
Sending 500, 100-byte ICMP Echos to 10.1.12.1, timeout is 0 seconds:
Success rate is 0 percent (0/500)
R2#
In order to see that the traffic hit the intended device, I had to debug icmp traffic on the destination. It definitely gets there.
John
John,
Thanks for the ratings
This is how you do load testing  to test integrity on links. you can generate 30-50mbps easily within seconds.
I generated up to 90 mbps on a fibre link within a few minutes
As I mentioned it doesnt wait for the reply and just bang!!  keeps flooding the link and  if you check the traffic on the link you will be able to see the numbers incrementing in heaps.
Kishore
hi kishore,
this is very cool!! +5
Hi  guys,
Thank you very much for your help and yes john that's exactly what i'm looking for very nice . Thank you for your Help.
Zied
