rate limit in catalyst 3560
mkamar
Is there a way to rate limit traffic BW in cisco switch 3560 port, as long as there is no rate limit command supported under the port configuration
spremkumar
Level 9
Level 9
Hi Kamar
AFAIK you can do the same using policy maps with policing command binded to the different class maps defining your traffic patterns.
do refer this link for more..
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_command_reference_chapter09186a00805b56cd.html#wp1864211
regds
spremkumar
Level 9
Level 9
Hi Kamar
regds
Thanks spremkumar for your kind support
