Rate limit UDP traffic on a single switch port
ryderse69
I need to rate limit UDP traffic on a port without affecting other traffic.
Would the below work or would this drop all other non-UDP traffic?
I could just change the ACL to IP ANY ANY but I would prefer to limit just UDP traffic.
mls qos
access-list 150 permit udp any any
class-map UDP_Traffic
  match access 150
policy-map Control
 class UDP_Traffic
  police 10000000 60000 exceed-action drop
int fa0/1
 service-policy input Control
Your config is ok. There is one class map called class-default in each policy that grabs all the remaining traffic. So you will not drop non-udp traffic.
Sweet!
I was not certain about that but had a feeling that was the case.
