Rcv-Err on notconnect SFP Port
TY92
Trying to understand the root cause behind an incrementing amount of Rcv-Errs on SFP ports that have no SFP Module or a connection. I should state, the switches that are experiencing this behavior are in a stack of at least 3. I've seen this occur on a WC-C3850-48P Gigabit SFP port as well as a 9300-48U TenGig SFP Port. Each time its a port that has no SFP module at all with generally no configuration.
Below is one such port and the presented errors:
interface TenGigabitEthernet2/1/7
end
TenGigabitEthernet2/1/7 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is redacted (bia redacted)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 711932690 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
708413 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
show interfaces tenGigabitEthernet 2/1/7 counters errors
Port        Align-Err    FCS-Err   Xmit-Err     Rcv-Err    UnderSize     OutDiscards
Te2/1/7       0               0            0             708382         0                      0
In each situation, this seems to occur on one of the N+1 "Member" role switches in the stack (480Gbps C9300 stack). Could the stack itself in some way be a cause of this? They increment about 10-30 input errors every 5-10 seconds on average.
This should not impact your day to day activitiy - but my suggestion as below :
16.6 is quite old on Cat 9300 - uplift to 17.3.5  (there are lot of bugs fixed)
C3850 also check any latest version to upgrade.
BB
6 Replies 6
balaji.bandi
Looks for me bug, what IOS code running on both,  what if the port admin down ?
BB
C9300s are on 16.6.4a
C3850s are on 16.6.4
I'll admin down a port today and report back the results.
BB
I thought that may be why as well, just have yet to find the exact bug # for this occurring on that version.
media type is unknown<<--
are SFP compatible with SW? are you use cisco or other vendor ?
No SFP or transceiver is in the module/slot, its empty. It's just a random port that is unused that has incrementing Rcv-errors for some reason.
