Re: Catalyst 1300 Not deleting commands
Hello Balaji
How to run default configuration on interface to remove the all configuration make it default.. Because this command is not running on cisco 1300
Mark Elsen
  - These devices do  not run IOS and don't have the 'default interface....' command available indeed.
     You need to fallback by looking at current settings on  a port and disabling them with the 'no....' command.
     Working manually....
 M.
