Re Configuring 6807XL switch
kesavroop
What are the options available to reconfigure cisco 6807 switch? and which is best option
BG:- The existing 6807 switch is used for one location and its is getting re-used for other building with new set of configuration.
Please anyone suggest with commands etc
5 Replies 5
Leo Laohoo
wr erase
reboot
Thanks Leo for your notes.
What I am looking for is the current configuration should be saved/archieved in system and wanted not use the same. options like renaming the config file and doing new config. is that possible?
thanks,
You can save and rename the config on the appliance itself or you can transfer the config to an external file server and then rename it there.
What is the commands used for those? Thanks,
One can save and rename the config files on the appliance or transfer the config file to an external drive and then rename the file.
