Re: QoS between Core Switch and Access Switch for Voice Traffic
InternetB
My question is based on the diagram attached.
I have a dual 6500 series core switches, CR1 and CR2 whereby I priotize voice traffic upto 30MB as it leaves for the mpls cloud.
Now the CRs are connected to 3650 switches. Would 'auto qos voip trust' on the interfaces on the C.Routers be
good enough here ?
ie) Core Router 1.
policy-map OUTGOING
class VOICE_TRAFFIC
priority 30000
class class-default
int f2/48
ip address 139.73.10.33 255.255.255.252
speed 100
duplex full
mls qos trust dscp
service-policy out OUTGOING
interface GigabitEthernet 1/9
auto qos voip trust <<<--- command that I have added
no ip address
mls qos trust cos
switchport
switchport mode trunk
end
On the switch end (original configuration)
interface GigabitEthernet0/1
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
end
Pls advice,
Cheers,
InternetB.
5 Replies 5
Edison Ortiz
Your 3560 configuration will work without problems but you should be concerned with the 6500 switch. I see you are applying LLQ on a regular LAN port on egress. This is not supported on the 6500 unless you install a WAN module (SIP/SPA or FlexWAN).
__
Edison.
Hi Edison,
Alright. What are my options here if I do not install the SIP/SPA or FlexWAN module to achieve the same result ?
Or rather can I achieve the same results on the box without the additional module.
Need to do some reading on this as well.
Thank you,
Cheers,
- InternetB -
Have a router as the WAN device.
Hardly. You are very limited on the QoS features without the WAN module.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1665987
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html#wp1000574
Edison
Hey Edison,
Thanks. How did you become so good mate ? ;)
Cheers,
- sanjay -
Not even close but thanks for the compliment :)
