read worng cpu value cat 3850
treca201420141
I have two switchs (model WS-C3850-24T), we are trying to monitor their cpu with cacti
we tried many Templates but all of them read the cpu of the first switch correctly but read the cpu of the other one wrong
so we tried prtg but got the same results
so what can cause this and how can we read the correct cpu value in with our SNMP monitors?
6 Replies 6
Mark Elsen
                                          - Why do you think the reading is wrong ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
my cacti graph reads value of 2 (the same value that prtg graph reads) but the output of the show processes cpu history command shows that cpu is over 50% and never go down
Leo Laohoo
3650/3850 are multi-CPU (single core) switch.  Each switch has four CPU (9300 has 8 CPU).
We use AKiPS and it can read all four CPUs (per switch).
when I used AKiPS it shows only one graph with stable value of 2% just like other monitors so how can I fix that?01.png
I don't know if AKiPS works with OIDs, but have a look at the document linked below
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/15215-collect-cpu-util-snmp.html#multiple
NOTE:  This is not the correct forum for AKiPS technical support.
What firmware is the switch running on?  What version is your AKiPS running on?  Mine shows up fine.
