RealPlayer + Cisco 851
solarapex
RealPlayer does not seem to work behind firewall. WMA streaming works fine.
stephen.stack
Level 4
Level 4
I think this maybe an MTU issue. Try reducing the MSS on the internal Interface
Interface Vlan1
ip tcp adjust-mss 1452
And perhaps then if you are using a dialer interface for PPP connnections try this command
Interface dialer 1
ip mtu 1492
Please rate posts
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
I'm trying to get some more information.
I found that this happens only with some of stream providers. It's not about RTSP yet, the problem occurs during negotiation. The server responds with HTTP 400 ('bad request'). And the most puzzling thing is when I swtiched the default browser from Firefox to Internet Explorer, it start working. But this is not the solution. I want to make it working with any default browser.
I'll rate all answers when I get my problem resolved.
Thank you for the reply.
Sorry for disturbing. It appears not a Cisco router problem. It was a problem with the default browser.
Thanks for your help!
